Televison & Video Logo
Posted on May 02, 2009
Turns its self off
I can turn my tv on and about 2 to 3 mins later it turns its self off
Anonymous
Level 1:
  • Contributor 36 Answers
  • Posted on May 03, 2009
Anonymous
Contributor
Level 1:
Answers
36
Questions
0
Helped
7347
Points
75
If your tv has a auto timer turn off you have got to manualy turn it off in the menu setting
Sony 60" wega tv it just turned it self off when i
it's telling you to replace the projection lamp, it has burned out,
My mitsubishi 60 in turns off by its self some times 5 min after you turn it on sometimes 5 hours and sometimes 5 days. you can tell when its about to turn off by line that flash on the screen. then they...
Well if your tv is older like the one in the pic it sounds like the bulb is overheating, you may want to vacuum the dust out of the back and make sure it isn't got block of air flow in the back and also make sure it isn't up against a heat source
2helpful
2answers
Sony kf 50e200a screen goes black and sound turns off for min...
TV has gone into "protect mode" to do just that to protect against the damaging failure that has been detected, you will need a servicer to diagnose the failure. Good luck and Merry Christmas!
Cars tv
ok I'm looking at the owners manual and it says that if you tv is plugged in to a higher voltage outlet in my turn its self off as a fire safty switch. So check to see if the plug in is a 210 outlet if so thats your problem otherwise it doesnt show anything else about it turning off hope that helps!
1helpful
Tv turning its self up?
is it showing it turn its self up on the tv by the bars or is the sound just getting louder by itself
is your remote a learning remote and does your tv have a preset volume that when turned on its to goto
if showing by bars one of the buttons on your remote is stuck or needs cleaning and
quite possibly getting an outside frequency thats interfering with your remote frequency
but if no bars are showing the service provider company i noticed my self there tv programs are flauxing in sound for some reason this to me gets annoying
2helpful
2answers
No Power in Mitsubishi VS-55705
Hi John This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB
Flickers on cold startup after 5 min then goes away in 2-3 min.
I had same problem. Tech's said the power was noisy. I cleaned up the power but the TV still did exactly as you describe. Problem will progressively get worse with longer bouts of flickering. I was under warrenty and sent the TV back. After 3 months I am still waiting for a repalcement.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
