Question about 2wire 1800HG Router (RG1800HG00)
Dell laptop local only connection - 2wire 1800HG Router (RG1800HG00)
My hotspot software is always displaying error in soft ap
I also had the same problems in my laptop, but I had tried many ways, this problems couldn't be fixed. A friend told me maybe I need to reintalled the system. However, I didn't want to do. Finally, I tried to use other wifi software. A program named OSToto Hotspot can run. You can have a try!
http://www.drivethelife.com/free-wifi-hotspot-creator.html
Jun 07, 2015 | Dell Vostro 1014 Laptop Computer
I can't find my local area connection...how can i can i get it?
may in service pack 2 there is no LAN but you have to reinstall to he your original service pack that you to contact dell and one more thing for you have to install drivers of connection or internet because your service pack2 has not installed drivers
Dec 16, 2009 | Dell Computers & Internet
Laptop connection issue
try plugging it in and then reboot the router and/or laptop. it needs to set itself up with a local ip address.
Does your modem have more than 1 ethernet port? if not you might need a router.
Sep 12, 2009 | Dell Inspiron 1501 Notebook
Dell 3300 Printer Adapter and Vista
Vista is tricky when adding networked printers.
Add printer by using a local device, not a networked device.  Assume the printer is connected locally to the machine.
Feb 01, 2009 | Dell Inspiron E1705 Notebook
Ethernet adaptor and Local Area Connection 2 cable unplugged
Is that an external usb nic card? you can just directly connect it to the usb port.
Sep 07, 2008 | Dell Inspiron 1150 Notebook
Ethernet controller friver
There is no availabe network driver for this Latitude d600 found on the dell support website that will work for vista. Most probably this computer is not configured to work with vista.
Call Dell Technical support for answers.
Aug 26, 2008 | Dell Latitude D600 Notebook
Local internet connection on dell laptop
i assume you are connected using wired or ethernet connection on a modem or with a router...? try to release or renew your IPs also what's the OS of this laptop? if it's on windows, run ipconfig from the command prompt, if you got an IP starting with 169.xxxx....
release and renew it. if it's a Mac, trash tcp/ip.
Apr 08, 2008 | Microsoft Office Outlook 2003 for PC
Connecting to the printer via a local network
Check network settings, you can browse the network. If you have an static ip let me know.
Best regards
Rafique
Feb 19, 2008 | Dell Inspiron 6400 Notebook
2wire 1800HG Router (RG1800HG00) Logo
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
efs_perpends
efs_perpends
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
