SOURCE: loading a stanley electric stape/nail gun
The problem you are having is common, so don’t feel bad. I learned all of this helping another individual that had no idea how to use this tool. The confusion comes from the fact that it loads differently than most staplers. The staples are NOT loaded on top of the pull out shaft; they are inserted directly into the slot that opens when you pull the shaft out. The other big issue is a safety feature. If the nose of the tool is not placed firmly against a surface, it will not fire. Go to Stanley’s website’s knowledge base and type in the model number TRE550, and you can get a PDF of directions. Here is a step by step with a pic below: Unplug the tool. Squeeze the end of the shaft at the rear bottom of the tool and pull out the shaft. Flip the tool over on it’s back. Insert the staples, (points up) and then slide the shaft back in. Plug it in, press the on button (under the the power cord in the back). Press the nose squarely against the material and press the trigger.
SOURCE: Need help loading staples in my Stanley electric staple/nail gun
there should be a button / lever at the rear press it and it should open so as to insert the staples
