2001 Acura MDX Logo
Posted on May 02, 2009
Acura tl 2008 CODE ERRORE
Acura tl 2008
i just took my car to the bodyshop to get it fixed. my radio started with error 1, error 2 and now its at Code Errore. what does that mean? i found my radio code. wont let me input it
trueshocker
Level 1:
  • Contributor 23 Answers
  • Posted on May 12, 2009
trueshocker
Contributor
Level 1:
Answers
23
Questions
0
Helped
16704
Points
62
Radio is locked out from installing incorrect code to many times need to disconnect battery for couple minutes then reconnect and install correct code
Radio is reading code error e .i need code for 2008 acura mdx i dont have manuel what could i do?
You will have to contact an Acura dealer. Given the VIN number of your car they can tell you the radio code as long as it is the original radio.
Acura TL 2001 Raido code
Is the code on the card correct, maybe a previous owner wrote it down wrong ? The code can be found on the left side of the glove box... on the left outside wall of your glove compartment after u open the compartment. Any good ?
How do you input radio code on acura tl 2004 if it says erre?
Look for the code on the outer left side of the glove box, top number is the code, the bottom number is the serial. Just saved you some time and money. Now if you could explain how to get the radio to prompt code entry instead of error. Tried removing fuse under the hood and disconnecting the battery terminal to prompt code entry, to no avail.
Need code for my acura tl 2000 model
If you mean the RADIO code........
The radio code is printed on a card, that is inserted in a slot at the front of your user's manual.
When you start the car, and the radio says CODE, all you do is key in the code numbers using
the radio presets buttons numbered 1-6 below the display.
2answers
2002 acura 3.2 tl radio code errors
You will have to go to dealer to have unlocked. The vehicle has built in theft lock system in radio. Most of them have code stored in radio that needs to be pulled before removing battery.
2answers
I need the radio code for my acura tl 2000
Go here: http://owners.acura.com/ Register your vehicle. Here you will find out how to acquire the code.
2000 acura TL, had work doen and radio code indicates error -1 and error-2
You have to do this: If you have jumped or replaced the battery at anytime this will happen. You have to get the serial number off the radio by removing it or partially taking it out to see the numbers on it try not to remove any cords. With the stereo out (to make sure you get the right number off of it) call an Acura dealership with the number and they will give you the another number to enter into the stereo and directions on how to punch the numbers in. Make sure while you have the stereo out you write the serial number down and keep it in a safe place also the number that the Acura dealership gives you because if you sell the car or if it happens again its easily accessible. Good Luck!
5helpful
3answers
SERVICE DUE SOON LIGHT
Press odometer reset/adjustment shaft in, hold in and turn key to run position. Keep holding in the reset shaft in for about 30 seconds. release shaft. turn key off. restart car. Service Light should go off in about 5 seconds.
Top Acura Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you an Acura Expert? Answer questions, earn points and help others
