Question about GE 13.7 cu. ft. General Electric Upright Freezer FUF14SUR
Ge upright freezer not freezing - GE 13.7 cu. ft. General Electric Upright Freezer FUF14SUR
5 Related Answers
Anonymous
  • 161 Answers
SOURCE: GE upright freezer
If this is a frost free model the fan could be bad. If not frost free it is probably low on freon. I don't recomment fixing this as you can never really trust the freezer again. Most of the time the leak can't be found and adding freon is only a temp solution.
Posted on Jun 30, 2008
Anonymous
  • 11 Answers
SOURCE: My GE upright freezer does not get cold.
Sounds like the system is low on freon. The other common problem is a dirty condenser. Insure the condenser is clean, if it is. You will need to charge the system with freon. Which only a qualified refrigeration tech should do.
Posted on Nov 28, 2008
duby1990
Justin Duby
  • 370 Answers
Sounds like you are low on freon.
Posted on Dec 01, 2008
Jon Edmonds
  • 23 Answers
SOURCE: my ge upright freezer dosnt
It might be another problem. Unless your unit was damaged there is no reason why R-134a would have leaked, of course, could be a factory defect. I had similar problem with my old Norge, now about 43 years old. It did not cool either. reason was the electric resistance heater imbedded in the evap coil was burned out. Solution was a mechanic added a pyrex glass tube with electric resistance hetaer below the coil, wired it up to the defrost timer and it has worked for the last ten years.
Posted on Jan 14, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Freezer starting to defrost
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 02, 2010
OLDER G&e UPRIGHT FREEZER PLUGGED IN RUNNING BUT
replace the ptc overload/relay on the compressor and it will cool again
Sep 11, 2011 | GE Freezers
My ge upright freezer is getting cold, but it is not freezing the food
check the door is closing tight first,,if it is try turning the thermostat down a bit more,,if that dont work you may need a new thermostat fitted and maybe even a re-gas and a new compressor
how old is the freezer???
Aug 21, 2010 | GE 16.7 cu. ft. / 473 liter Upright...
My kelvinator upright freezer stopped freezing and it just kicks on and kicks right back of what could be wrong with it?
Start Relay/Overload or Compressor is bad. A bad compressor can make a Start Relay/Overload go bad but the only way to find out if compressor or Start Relay/Overload is bad is to replace the Start Relay/Overload if it starts and stays running you fixed it if Prob. returns in a week or so or if you have the same Prob. after replacing the relay the compressor is bad.
May 20, 2010 | GE 13.7 cu. ft. General Electric Upright...
Freezer gets cold but doesn't freeze
check tem.p inside cabinet and let us know what you find
Jun 29, 2009 | GE Freezers
GE Freezer Not Freezing
I am not an expert, but if the defrost heater is not working, then maybe when it was unpluged the coils didn't completly unthaw. If not, the freezer still will not cool properly.
Mar 25, 2009 | GE 13.7 cu. ft. General Electric Upright...
Nov 28, 2008 | GE 13.7 cu. ft. General Electric Upright...
GE upright freezer
Jun 24, 2008 | GE 16.7 cu. ft. / 473 liter Upright...
GE 13.7 cu. ft. General Electric Upright Freezer FUF14SUR Logo
57 people viewed this question
Top GE Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a GE Freezer Expert? Answer questions, earn points and help others
