I phone 5
Unable to connect to the wifi
  • Computers & ... Master
  • 27,725 Answers
What Type/Brand of router ?????
Apple's iPhone is a multimedia connectivity tool.
As such, the iPhone employs a sophisticated system to keep you connected to the web via WiFi signals so that you can stay up to date with email, mapping and media.
To use the iPhone's WiFi feature just follow these steps.
Tap a network.
If you have not yet used your iPhone's WiFi or if you're in a new WiFi area, the iPhone will show you a list of available networks.
Tap the network that you want to connect to in order to connect.
If there is a password required a little lock icon appears.
Enter the password to connect to locked networks and continue to surf the web.
Monitor your signal.
As you use your iPhone, especially if you're moving around, you should take a look at the signal strength of the connection.
The strength is indicated by a small, black broadcast symbol that stacks arches, or rounded bars, on top of one another.
The more bars there are the better the signal.
Make connecting to WiFi automatic or manual.
The iPhone is equipped to automatically search for available networks and connect you to one.
If you do not want the phone to search for networks, select the "WiFi" option on the phone's menu.
Then select either the on or off option of the "Ask To Join Networks."
Turning this option off requires that you find networks manually.
Forget a network.
Once you connect to a WiFi network once the iPhone automatically remembers the network and connects you to it at a later opportunity.
To forget a network so you don't get automatically connected choose the "WiFi" option on the menu.
Then tap the right arrow button next to one of the networks that the iPhone already remembers. Then tap "Forget This Network" to erase the phone's memory of the network.
Troubleshoot Wi-Fi Connection Problems on an iPhone
If you experience Wi-Fi connectivity issues on your iPhone, you may need to reset the Wi-Fi connection.
Your connectivity issues could be caused by the wrong password if you are having trouble logging into the Wi-Fi network or from a problem in your iPhone's settings.
By resetting the Wi-Fi connection, you are clearing out the previous settings created when you first connected to the network.
Tap the Settings icon on the iPhone's home screen, and tap the Wi-Fi tab.
Swipe the switch on the Wi-Fi tab to ensure Wi-Fi is enabled on your iPhone.
Tap the blue arrow button on the network tab you are connected to in the network list, and tap "Forget this Network."
Tap the "Forget Network" button that appears on the pop-up menu to confirm the action.
Tap the Wi-Fi Networks tab in the upper-left corner to return to the previous screen, and tap the network's tab in the network list to re-join it.
Press the Home button on the iPhone, and tap the Safari icon on the home screen to test the Wi-Fi connection.
Tap the blue arrow icon on the network's tab if the connectivity problem persists, and tap the "Renew Lease" button at the bottom of the network's window.
Tap the "Renew Lease" button on the pop-up box to confirm the action.
Tap the Home button on the iPhone, and tap the Safari icon on the home screen to test the network connection.
Posted on Nov 12, 2013
6ya staff
SOURCE:
Connecting to Public wifi?
most public wifi would need you to sign in by accessing some specific page. they still want to know who you are.
Aug 26, 2016 | Samsung Cell Phones
Can't connect iPhone 5s and hp 1220c
Sir/Madam
iOS: Troubleshooting Wi-Fi networks and connections Symptoms This Issue is Related To Your apple Mobile And Make Sure You Already Install HP Printer Software In Your Desktop or Laptop. If yes I suggest you perform below Solution for Your Apple 5s and HP Priter Connectivity Issue:
Learn how to troubleshoot WiFi.Issues you may encounter while using your iPhone, iPad, or iPod touch.
Resolution Occasionally while using your iOS device, you may notice unexpected Wi-Fi behavior: Difficulty locating or connecting to a network
Unexpected Wi-Fi signal strength or disconnects
Inability to access the Internet
Not automatically connecting to WiFi when expected
Follow these steps to troubleshoot the above issues:
1.Be sure you're in range of your Wi-Fi router (access point).
2.TapSettings WiFiand turn WiFi off and on. If your Wi-Fi setting is dimmed,follow these steps.
1.Confirm that your Wi-Fi router and cable or DSL modem are connected to power, turned on, and connected to the Internet. If not, refer to your network administrator or Internet service provider (ISP) for assistance.
2.Restart your iOS device.
3.Tap Settings WiFi and locate the WiFi network to which you're connected.
4.Tap and Forget this Network.
5.Try to connect to your desired Wi-Fi network.
Note: You may need to enter your Wi-Fi password again if your network requires one.
6.Turn your Wi-Fi router off and on. If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
7.Update your deviceto the latest version of software.
8.Update your Wi-Fi router to the latest firmware. For AirPort Base Stations,install updates using the AirPort Utility.
If the issue is still unresolved Follow the steps below for the issue you're experiencing.
Collapse All'Expand All
Unable to locate a Wi-Fi network
Unable to connect to a Wi-Fi network
WiFi disconnects or signal strength is less than expected
Unable to access the Internet while connected to Wi-Fi
Unable to automatically connect to Wi-Fi
Additional Information Find information onconnecting to a Wi-Fi network.
Some third-party routers may not be compatible with all iOS devices, even after updating to the latest firmware. If your iOS devices can successfully connect to other Wi-Fi networks, contact your router's manufacturer to ensure that your router is compatible with your iOS device.
See recommended settings forconfiguring your Wi-Fi router for use with iOS devices.
Notes
1.iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models supportWLAN.
2.If needed, please consult with your network administrator (which may be your Internet Service Provider) for assistance with this step.
3.iPhone 5, iPad devices, and iPod touch (5th generation) are the only iOS devices that can connect to 5 GHz networks.
If You Still Haveing Problem then Visit official Below Apple Website URL Link:
http://support.apple.com/kb/ts1398
Or
In case you still having HP Printer Issue Then Follow Us On:
HP Printer Support
Feb 12, 2014 | HP DeskJet 1220c InkJet Printer
IPhone 4s is unable to scan/connect/join wifi network. Please help?
Hey there could you be more specific, are you saying thst it won't connect to any wifi network or just already saved ones?
Dec 19, 2013 | Cell Phones
Unable to connect my blackberry to wifi. it says unable to authenticate network.
Try a hard reset: With power ON, remove the back cover and pull out the battery. Wait about a minute then replace the battery and cover. Power up and wait patiently through the long reboot 5 minutes.
Also check the wifi encryption is compatible with your phone?
Maybe an option to goto a cafe with a wifi hotspot and try logging in there ... does that work?
cheers.
Oct 22, 2013 | D-Link Dlink Dir-600 Wireless Router...
I have a samsung galaxy gt-i9000 but my wifi nolonger works when i turn it on it says unable to scan twice then turns itself off.
Hello there,
You will need to be sure that there is wifi turned on in the area that you are trying to use your phone.
Then you try to go through the wifi list on the phone and delete all the wifi that it has ever seen and worked with. Then you turn off the phone for about 5 minutes, then you turn it on and turn on the wifi on the phone and search for the wifi available, that way it will search for the available wifi and connect to it.
Thank you for using fixya Caseytech
Jul 05, 2011 | Samsung Galaxy S GTI9000 Smartphone
I bought a Nokia E71 Saturday and everything works, including the WIFI, except I am unable to connect to internet going down the hiway or anywhere away from a WIFI connection.
If you don't have a WIFI connection then you don't have internet. The only way to have internet without wifi is with a data plan from you provider.
Mar 08, 2011 | Nokia E71 Smartphone
I am unable to connect my Samsung monte s5620 with my bsnl teracom wifi modem. Although, I can connect it to my pc.
1.Verify the network key you have entered in the WIFI settings.
2. Check the Encryption type is TKIP.
3. Uncheck static IP in advanced settings.
4.Protocol must be set to HTTP in WIFI settings.
Nov 16, 2010 | Samsung S5620 Cell Phone
Wi-fi connection problem
There are 2 ways to approach your problem.
  1. Un-protect your wifi connection by removing the password. This is risky since other wifi gadgets can readily connect to your network.
  2. Configure your Samsung phone to connect to your password-protected wifi. Make sure that the wifi protocol of your phone matches that of your wifi router. Example, make sure to set WPA or WPA2 on both device.
May 08, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
Since upgrading my N95 8GB firmware from 11.* to the latest 30.* I am unable to establish a WIFI connection. It will find WIFI spots and prompt me to enter the key but doesn't get any further. This affects...
I have a work-around for my home wifi router by assigning a static IP, subnet and DNS gateway. Found this solution on a blog. Of course, it won't help me connect to other WIFI points using dhcp but I can live with this for the moment.
Jun 10, 2009 | Nokia N95 Cellular Phone
Wifi
go to your wireless settings, where you can see the connections that your phone can find, hold your stylus on the connection and remove the settings. after that set up a new connection. problem should be solved
May 24, 2008 | HTC Touch P3450 Smartphone
Computers & Internet Logo
130 people viewed this question
Ekse
Marvin
Marvin
