Washing Machines Logo
Posted on May 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wont start key symol appears
Wont start key symbol appars
Anonymous
Level 3:
  • Master 15,935 Answers
  • Posted on Sep 15, 2010
Anonymous
Master
Level 3:
Answers
15935
Questions
19
Helped
5033319
Points
35540
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
What is the symbol rate of 256 QAM?
Without knowing the bit rate, you would not be able to calculate the symbol rate; and without the symbol rate you would not be able to calculate the bit rate.
Based on the below referenced web sites, you can see that the symbol size for 256 QAM will be 8 bits without considering error detection/correction. The QAM value is determined by taking the number of bits/symol and rasing 2 to that given power.
8 bits/symbol => 2^8 => 256 QAM
Simple definition of 256 QAM
256 QAM dictionary definition 256 QAM defined
Comparisons of different QAM to demonstrate bits/symbol to QAM ratio
Comparison of 8 QAM 16 QAM 32 QAM 64 QAM 128 QAM 256 QAM Types
HOW TO USE THE SYMOL KEY
Hi Anonymous,
This is in regards to using the symbol key on the Dell Vostro 1015. I will be glad to help you. Please let me know which symbol key are you trying to use if you want to use the default symbol keys like #, $, %, etc then you may hold the shift key and press the desired key on the keyboard. However, if you are talking about any other key then let me know which one it is I will then check and suggest what can be done.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Why wont my vehicle start when there is a lock symbol on the dash?
I had this same problem with my 2004 gmc envoy. Mine was a key problem. I had a 2001 impala that had identical keys that contain a chip that is read by the ignition switch. Both of my keys were near each other on the keyring and when the impala key was to close to the ignition the truck would not start and the light came on that looks like a lock. I took the impala key off the keychain and never had another problem.
Key on display wont start
Your washer is in the "child lock" mode, hence it won't allow any program. Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. If nothing is pressed within 10 seconds.following this the menu will close and it will default to program in the display. Once you see that in the display, press the "select" button until "CHILD LOCK :OFF" appears in the display. Finally by pressing the start/pause button the key symbol should disappear - confirming you have successfully exited the child lock program.
Pl click if helped.
4helpful
Greater than symbol? in keyboard?
Dell QWERTY keyboards greater-than symol is produced by the key sequence
SHIFT-. (shift period), like any other QWERTY keyboard. Your greater-than symbol probably wore off.
The Less-than symbol is produced by SHIFT-, (shift comma).
Idk wat the symol <:L>
In HTML (2.0) < means "less-than sign"
> means "greater-than sign" >
I would expect L> to render as; L>
As far as I know there is no specific L> symbol.
5helpful
I have a bosch clasixx machine there is a symbol like a key on timer and machine wont start how do i get rid of this
Hello, Welcome to fixya.
The Key symbol means the lock has been activated some how.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry and good luck going forward.
Regards,
Macmarkus :)
2answers
Eject
i need this program
Att.
George
Top Washing Machines Experts
john h
