Question about Apple iPhone Cell Phones
Connecting iPhone 5 to ANT+ devices
I found Bluetooth 4.0 jackets and bike mounts but none provide compatibility to my Garmin ANT+ devices such as the heart rate monitor (HRM) and the Speed/Cadence Sensor (SC), both from Garmin and currently working on my Garmin bike computer. Any suggestions? Started visiting http://www.thisisant.com/directory/
Harrison Chin
    New Friend:
The Viiiiva Heart Rate Strap is an ANT+ to iPhone Bridge, along with the Wahoo RFLKT+ Bike Computer, personally I think I'd find the strap more useful.
Posted on Nov 11, 2013
5 Related Answers
Anonymous
  • 13 Answers
SOURCE: my iphone 4 does not
Dear ito824mumbai,
iPhone will connect only with other Apple devices and only with Bluetooth headsets. It wont connect with other devices.
Regards,
Posted on Mar 01, 2011
Bajanguru
Sylvester Brathwaite
  • 7752 Answers
SOURCE: i phone
you should be able to view any msgs or pictures that are sent to you without going there...would have to check this out for you
Posted on Oct 15, 2008
Anonymous
SOURCE: amazon.com/bb app won't download to BlackBerry Bold 9000
I had the same problems, it turns out my browser options were set to identify my bb browser as internet explore, you can also set it as firefox, once i changed it back to blackberry it worked fine, just go to browser menu options and change it.
Posted on Jul 29, 2009
Anonymous
  • 7 Answers
SOURCE: how to connect to bluetooth (ant) device with lg rumor phone
Not sure if you have paired your bluetooth with your phone yet. Hold your bluetooth button down untell it flashes (usualy blue and red) continuously your phone should then find your bluetooth then it will ask for a code. Usualy the code is 0000. If not make sure your bluetooth is turned on:)
Posted on Oct 26, 2009
Anonymous
SOURCE: http://www.nodevice.com/driver/MOTOS.../get39407.h...
no connect with pc
Posted on Jul 27, 2010
Need to download iOS 5
to update to iOS 5 is only possible on iPhone 3GS / 4 / 4S with connecting the device to iTunes on a computer.
- Plug the iPhone to your computer and open up iTunes under devices click on your iPhone and then click on check for update.
latest iOS possible:
iPhone 1 = iOS 3.1.3
iPhone 3 = iOS 4.2
iPhone 3GS = iOS 6.1.6
iPhone 4 = iOS 7.1.2
iPhone 4S = iOS 8.1.2
iPhone 5 = iOS 8.1.2
need-download-ios-5-rb1lxwwedrgyiycdlihok4mn-5-0.jpg need-download-ios-5-rb1lxwwedrgyiycdlihok4mn-5-2.jpg need-download-ios-5-rb1lxwwedrgyiycdlihok4mn-5-5.jpg
Mar 19, 2014 | Cell Phones
I can't adjust bluetooth,there is no "bluetooth" icon.
The Nuvi 755T does not have bluetooth capability. See this link to see the specifications of the 755T from the Garmin website:
https://buy.garmin.com/en-US/US/prod14933.html
Bluetooth wireless technology No
You would have to have a Nuvi 765T to have bluetooth
https://buy.garmin.com/en-US/US/prod14926.html
Bluetooth wireless technology Yes (with A2DP technology)
Aug 13, 2013 | Garmin nuvi 755T Car GPS Receiver
How can I my 2004 Honda Goldwing mic to work with my Garmin Zumo 665 to answer my cellphone? The phone bluetooth connection works fine with the Garmin in my car, but my Honda mic does not work through the...
The microphone input from the Zumo 665 motorcycle mounting cradle is the smaller 2.5mm jack.
Be sure to use this one as some microphone jacks will require a 3.5mm to 2.5mm adapter.
The audio output is the 3.5mm jack.
Be sure not to confuse the two.
It may be necessary to have a custom 5 or 7 pin DIN adapter made to connect between the GW audio system and the Zumo.
It would be best to consult with your local Honda GoldWing dealer for more information on interfacing the GW audio system.
Oct 07, 2011 | Garmin zumo 665 GPS Receiver
BlueAnt pairing with iphone...help
Just got off the phone with Apple and Blue Ant tech support.
If everything is workon g on both devices you probably need a memory dump on your headset.
1. Power off both devises
2. Power on iphone
3. Power on blue Ant - not in pairing mode - you should see 1 blue blinking light on MFB
4. Make sure iphone bluetooth is on and searching for devices
5. On Blue Ant, hold both volume buttons and MFB at the same time until you get a fast blinking blue light.
6. Check iphone it should now recognize device.
7. When Blue Ant shows up on phone press it so it completes the pairing priocess
Jun 24, 2009 | Blueant Z9 Wireless Headset
My g3 iphone says blue ant st3 password incorrect but it's the only one they give you...won't connect with my phone
Hi - I had the same problem setting up my 3G S. Here's the solution. In "Settings/General" set the Bluetooth to "ON". Turn your ST3 OFF by holding the green button until she says it's Powering Down. Now press and hold the green button ON until Language Selection (British English) option. Select language by pressing green button again. Next she will say "Device Found-Paring Successful-Enter password 0000". Enter 0000 and your phonebook will start downloading. There ya go!
Jun 07, 2009 | Blueant Blue Ant 091193 Supertooth II...
Bluetooth icon missing
The Nuvi 750 does NOT include bluetooth capability. I don't know what you saw, or what you think you saw, but Garmin's website is very clear on this issue. NO BLUETOOTH WITH THE NUVI 750
Feb 07, 2009 | Garmin Nuvi 660 GPS Receiver
MY Garmin 405 wont download data. It make the connection and gets to the tarnsfer point then "transfer failed. I've one route downloaded last week but none since. I tried: resetting both...
I got the same issue and it was because of a software update to ANT+ agent being not compatible with the 405.
here is what I got from Garmin Support.
This solved my problem:
There is currently an issue that has been identified with the latest
version of the ANT agent where it will not transfer data to the computer
from a 405cx. To resolve this please follow these steps
1. If the device has paired it will need to be removed. Right Click on
the ANT agent, select Device Settings then click Remove Device.
2. Right Click the ANT agent and select Exit to close the ANT agent
3. Go to the Control Panel, select Add / Remove Programs and uninstall
the ANT agent.
4. Reboot the computer
5. Download the previous version of the ANT agent from http://www8.garmin.com/software/GarminANTAgent_221.exe
Run this file once it has downloaded
7. Turn on the pairing on the watch ? to do this go to Menu > Settings
> ANT+ > Computer > Pairing (on).
8. Enable pairing on the computer - right click on the ANT agent icon
and select Pair With New Devices > Enabled (this may already be enabled)
The Forerunner and computer should now pair, please be aware that it can
take several minutes for the computer to find the watch.
May 14, 2008 | GPS
Garmin NUVI 660 BlueTooth
I had the same problem, and this is how I fixed it. Now it's working fine.
Thank you for contacting Garmin International,
If you are currently running the most current version of bluetooth software, and you are still seeing issues where your compatible phone is still not connecting properly, please try the below procedure, which will reinstall the version of bluetooth you have downloaded in case there was any corruption during the transfer or installation of the bluetooth version.
1. Power the unit on
2. Touch View Map
3. Touch the ETA/Speed button in the bottom left hand corner.
4. press and hold your finger over the speedometer for 10-15 seconds until a new screen appears.
5. Touch next at the bottom of the screen until the top blue banner reads Bluetooth Status.
6. Touch UPDT P, then Touch yes.
7. At this point the unit should go to a page that says Updating Bluetooth Firmware, allow this to finish, once finished, press quit, then press and hold the back button. At this point, go back through and try to connect your Bluetooth device again.
Dec 29, 2007 | Garmin Nuvi 660 GPS Receiver
Bluetooth enabling
Does it work properly otherwise? Is this the only place it gets stuck?
Sep 16, 2007 | Garmin StreetPilot c550 GPS Receiver
Missing bluetooth software
The 300 does NOT have bluetooth. See this Garmin link:
https://buy.garmin.com/shop/shop.do?pID=339
The 360 has bluetooth. In order to have bluetooth, you must have the main board inside that has the bluetooth circuitry AND the firmware to support it. The 300 does NOT have the circuitry for bluetooth.
- Jim
Sep 08, 2007 | Garmin n vi 300 GPS Receiver
Cell Phones Logo
155 people viewed this question
Top Apple Cell Phones Experts
Marvin
Marvin
sandyp4ever
sandyp4ever
Level 1 Expert
B Louis
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
