Do not know how to proceed to replace the wheel.
Remove anything in the unit that could spill or tip over. Raise the front leveling legs to allow unit to roll. Slide the unit out from the wall. Place something between the refrigerator and the wall to protect surfaces. ***Make sure you have someone to assist with this next part. Tilt unit to the side and lean it against the wall to raise up the roller to be replaced. There is a metal base that supports the rollers, compressor, condenser and fan motor. You will see a heavy duty metal pin that goes through the roller. Bend down the metal tab in the base to remove roller pin. Replace the roller, reinstall bin and bend the tab back up. Carefully set the refrigerator back down on all four rollers. push back in place and screw down the front leveling legs.
Do you loosen the whole try
