Is the water on? sorry had to ask. after that, you have a valve fault (probably) or board fault (unlikely). with a multimeter check there isn't an open circuit over the valve terminals. if so, get a new valve and chuck it in.
Because you are not getting an error message, I agree that the controller card is malfunctioning. Almost everthing else would triger an error.
Recommend replacing the controller card.
code indicates pressure switch not tripped after 6 min...slow fill,water siphoning out(drain too low or too tight in standpipe)possible pressure switch under top right side
The PE error code indicates that the machine has a water pressure sensing error.
Check and clean the filters on both sides of the inlet water line.
