https://forums.radioreference.com/radio-shack-scanners/346157-does-not-power-up.html Might be a diode thatās blown. This forum at that web address is great for info on it.
The best programming instructions for your scanner are found in the owners manual which you can download and print, at no cost, here: http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/RadioShack-OlderManuals/Pro-96/pro96.pdf
For a comprehensive database of active frequencies and trunking systems in your new area, and a lot of other useful scanning information, visit: www.RadioReference.com
Your PRO-96 has 10 banks of 50 channels, giving you access to 500 channels for conventional systems. It also has 11 banks of 500 channels, giving you access to 5500 users on trunked systems. Detailed instructions for programming the scanner are contained in the factory operating instructions, which you can download and print at no cost here:
Your scanner is capable of receiving conventional, trunked, and digital (APCO-25) signals. As such, programming options are detailed and much too involved to be presented here. I suggest that you review the operating manual for your scanner (which can be downloaded/printed by following the link below), visit www.RadioReference.com for a comprehensive database of active frequencies and systems in your area, and consider joining a users group for the PRO-96. You can find groups on RadioReference, Yahoo, etc.
MO is for monitoring MOtorola trunking systems and will only work if you have programmed a system into your scanner. Most fire departments are using conventional, (FM) transmissions, not trunked systems - mainly so that volunteers and neighboring departments can follow the action and respond if needed. For a comprehensive database of active frequencies and systems in your area, visit:
Need the manual for your scanner? You can download and print it here:
buy a high fequency to low frequency converter from radioshack/motorworld/halfords. it will splice into ur existing speaker connections and give you rca channels
