Moved the fridge into new house set up waterline made a few ice cubes and now none are being produced. Interior water dispenser has not worked at all since we set it up
SOURCE: No water and ice cubes
Check the water valves in back of frig. and see if working.. make sure you got a water supply valves may be plugged
SOURCE: Ice Maker
check the temp inside the frezeer it should be 0 degrees at all times if is higher then that then lower temps and clean condenser coils . if it is zero then repl entire ice maker the thermostat inside ice maker is not closing when it should and in return takes longer to cycle ice.
SOURCE: Kenmore Elite Trio 22.4 Cu Fridge - Flecks of "Tin Foil" in Ice
Perhaps the solution to to change out the ice maker unit
SOURCE: cold spot not making ice
you may need to plaug in the solonoid
look for a tan and whit connector
and the paddles on the soloinoid
right behind the panal where you connected the watewr
SOURCE: MY ICE MAKER WON'T WORK
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
