You will need an ohm meter, and the know how to use it. Turn on your meter to resistance check, unplug one or both of the wires going to it. Place the two leads on each of the terminals. If you have an anolog meter (has a pointer that moves) when you touch them, the meter should move towards the opposite end. If digital, it should show some sort of reading around zero or so. If neither moves you have an open circuit, and the limiter is bad. Now if it's a thermistor, checking of this needs to be checked with a certain value at a certain temperature. Usually cheap enough to just change if you get a bad code or uneven or no heating.
