Sony MHC-GX555 Mini Hi-Fi System Shelf System Logo
k
kim carter Posted on Nov 10, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Prtotect on screen
Says protect on screen wont work
RAVI CHETTY
Level 2:
  • Expert 158 Answers
  • Posted on Nov 12, 2013
RAVI CHETTY
Expert
Level 2:
Answers
158
Questions
Helped
50931
Points
280
Hi the audio stage is blown.I suggest you take it to a technician to have amp module replaced
When switching on my camra it shows protected card across the screen and wont work
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
1helpful
Write protect on screen
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Touch Panel Broken
there is a guy on ebay that fixed mine Trbilea1999
he repaired my touch screen and updated all the software
Hi My name is Maggy i lost my Nokia E63 n one of my mmc which had data was password Prtotected , Card is with me n i rember password even but i have lost the Phone so Pls help me how to unlock MMC by...
Just search in google and download the app'MMC PASSWORD FINDER'. Then enter your memory card into a mobile set and run that application. You will see your password in the middle of some unrecognised symbol. It will be written in english. You should download supported app for your handset in which you will enter memory card. Cherrs....
Drive is write prtotect is not formate & copy
Is this USB drive? Write protect is a small switch on the drive. Look closely for switch, slide it to opposite position. Try again to copy / format / whatever.
I purchased Ipod Touch for Christmas on Friday 11/27/09 and I went back to Walmart today to purchase a 2 year extented service. How does this protection work? Do I have to register the product since I...
you probably wont have to register but i dont know. but the protection works so that if your Ipod fails (either software or screen stops working) you can send it in for a new one or just get it fixed. i dont know about walmart but the applestore wont fix it if you broke it (cracked screen or dropped in water) unless you pay a little extra $$$
Please help!
If the screen is clear that may work. but if its tinted you wont be able to see the image clearly without the tinted rough screen .But if its clear you should be ok, however the other screen will get broken super easy without the protective scren protecting it. New screens are exspsensive. The following link should have your screen.
http://servicemanuals.vstore.ca/
Display read protected and wont do anything
Usually, protect mode is enabled when the speaker output wiring has shorted together or is touching ground/+12V. I would verify that none of the speaker wiring has come loose.
2answers
Bottom screen wont respond to touch
Try closing and opening the device a couple of times, then try again, I think your flex cable is damaged...
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
