Question about Kodak EasyShare C340 Digital Camera
Sd card will not format c340 - Kodak EasyShare C340 Digital Camera
2 Related Answers
  • 102366 Answers
SOURCE: I have a new memory
The C340 works with MMC and SD cards. Your 16GB card is a SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use a MMC or SD card, which top out at 2GB.
Posted on Aug 27, 2011
  • 102366 Answers
SOURCE: where can I purchase and
MMC cards are nearly extinct and hard to find. SD cards should still be available at just about any department, electronics, or office-supply store. Be sure to get SD cards and not SDHC cards, as the latter will not work in the C340.
Posted on Feb 02, 2012
Kodak EasyShare C340,came with 512mbCard have tried two ScanDisk 4gb cards. It will not format either,,not locked. Do I need a special card for this camera
The C340 works with SD cards, which top out at 2GB. Your new 4GB cards are actually SDHC cards. While they fit into the slot, they are electronically incompatible and will not work with this camera. You need to use SD cards, 2GB and smaller.
Nov 09, 2012 | Kodak EasyShare C340 Digital Camera
I want to upgrade my card to more capacity. Mine is 512MB (came with the camera) Have tried ScanDisk 4gb and 8gb..The camera will not accept or format either. What do I do,,
Just purchased new SD card will not work
The C340 works with MMC and SD cards. Your new 4GB card is actually an SDHC card. While it fits into the slot, it will not work with devices that haven't been specifically designed to work with SDHC cards. You will need to stay with SD cards, 2GB and smaller.
Nov 26, 2011 | Kodak EasyShare C340 Digital Camera
I have a new memory card, a Toshiba 16GB, and my Kodak C340 says the card needs formatting. The camera will not format the card. Can formatting be done on my computer? If so, how?
Aug 27, 2011 | Kodak EasyShare C340 Digital Camera
The sdhc sandisk card is unusable after formatting it on my kodak easyshare c340
The C340 works with MMC and SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to use cards 2GB and smaller.
Aug 06, 2011 | Cameras
Where can I purchase and sd or mmc card for my easy share c340 camera
Nov 16, 2010 | Kodak EasyShare C340 Digital Camera
Can not format a 4 gb sd card to my camera
The C340 uses MMC and SD cards. Your 4GB card is actually an SDHC card, not an SD card. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work. You need to use SD cards 2GB and smaller.
Oct 26, 2010 | Kodak EasyShare C340 Digital Camera
Why can't I use an Adada 4gb SDHC card? It formats then tells me that this card is unuseable
The C340 works with MMC and SD cards, not SDHC cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work.
Oct 21, 2010 | Kodak EasyShare C340 Digital Camera
Kodak c340 easyshare when put memory card in it says memory is unusable! It is a HP sdhc 4gig card.
The C340 is designed to work with SD cards. While SDHC cards such as your 4GB card will fit into the slot, they will not work. You need to use SD cards 2GB and smaller.
Aug 08, 2010 | Kodak EasyShare C340 Digital Camera
Maximun SD Storage card size
http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/Kodak/Kodak+EasyShare+C330_Memory_Cards
Jul 12, 2008 | Kodak EasyShare C330 Digital Camera
Kodak EasyShare C340 Digital Camera Logo
79 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
