Question about Bosch 400 Watts MUM4422 Compact Series Stand Mixer
Sparks and large grating noise
Was using the mixer just fine, then it made a loud grating noise and the blender cap was spinning and moving up.
Posted by Peggy Stephens on
Mark Bown
  • 37 Answers
Sounds like the gearing has gone ...
Posted on Nov 10, 2013
Testimonial: "Okay, what does that mean? Is it fixable or dead?"
  • Peggy Stephens
    Peggy Stephens Nov 10, 2013
    It is actually a Bosch UM3 model
Sunbeam heritage series 2346
Some lubrication might be in order. Grease will dry out and cake so it won't lubricate what it's meant to.
Dec 12, 2016 | Sunbeam Food Mixers
Blakeslee Uni mixer model A702 I moved the lever (front top) side to side and it appears that the mixer is now out of gear. not sure what I did miixer worked great before that?
These machines were designed to disengage the gearbox when the cover (where the blender goes) is removed, the theory being less gear train resistance more power to spinning knives/blade. Is this the cover that you are referring to?
Jan 07, 2015 | Blakeslee Food Mixers
Kitchen Aid 550 Pro Mixer New Worm Gear and Worm Gear Follower Issue
It would be helpful to get the model number and serial number off of the bottom of the mixer. This will help determine if the gearing has changed at all.
Usually when a mixer is making a lot of noise after replacing the gears we can find a small nick or gouge in the gear. even the smallest damage can cause these mixers to make a lot of noise. Also if you have an older mixer there was a change in the worm gear from 53 teeth to 60 teeth on the gear. If your mixer originally took a 53 tooth gear, and you replaced it with the 60 tooth gear it will make a lot of noise like you are describing.
So first check your serial number, if the first 4 digits are after WL45 your mixer would have a 60 tooth gear, however if it is a WL44 or before you would have originally had a 53 tooth gear and this is what is causing the loud noise.
If your mixer is new enough that it took the 60 tooth gear, then take the mixer apart, clean and remove all gears, clean them off with wd-40 and inspect closely, even the smallest chip can cause a ton of noise.
If you have any questions, or you cannot find the problem feel free to contact us at The Mending Shed.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
We Repair Anything Under the Moon!
Apr 04, 2013 | KitchenAid New Professional 5.5 QT...
MY kitchen Aide mixer was running alittle rough /loud and now has stop completely. It is approx 24 years old and has never had any problems. It is hard to find a local repair [place. any suggestions
Two things you can do for a 24-year old machine:
1. Replace both motor brushes (Black large plastic Caps on each side
of the Moto Housing). Without these, the motor wouldn't even run.
2. Replace the Worm Gear (the cause of the Rough Loud noises)
Download a copy of the Repair Part List from Kitchenaid.com for
your model KSM90.
Also don't forget to tighten all the screws inside the mixers and use
fresh Kitchenaid Grade Food Grease for all the gears.
Jun 21, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Blender attachment does not work
It could be the drive belts. There are three. One for the motor to the belt drive. one from belt drive to bowl mixer spindle. one from belt drive to mixer spindle. mine started to do the same thing. I ordered the belts from Bosch.
Jun 08, 2010 | Bosch 700 Watts MEK7000 Concept Series...
The mixer works, but the motor is very loud.
I would first check that the motor brushes aren't worn out. They are held behind the black blastic caps on either side of the mixer head. These caps unscrew and the motor brushes are held in with a spring. Note the direction they go in, they are keyed and will only work when put in the right way. Use a torch to check. There is a picture of a new brush here: http://kitchenaidmixerspares.co.uk/Home/tabid/36/ProductID/88/Default.aspx
If this is not the problem the next stage would be to take the head apart to check the state of the gears and grease.
Jan 24, 2010 | KitchenAid K45SS Classic Stand Mixer
Noisy, high pitched whirring MUM6622UC/01 Bosch Universal Mixer
My wife's bosch mixer had a similar problem but it was a very loud grating problem. I talked to the bosch dealer in Utah, sorry, I've forgotten which one-- the one that does the repair. This is typically what happens: the seal on the blender wears out, which results in fluids from the blender dripping into the motor, onto the upper motor bearing. So, the upper bearing corrodes and is what is causing the bearing failure and the loud noise (needed hearing protection to operate it). I was lamenting the cost and time it would take to ship the mixer both directions (not actually that much compared to the price of the mixer), and he said he would sell me the bearing and the bottom replacement part of the blender that was leaking. So, I did the repair myself, but it took awhile, and I had to build a puller for the bearing to get it off the shaft, modifying a harbor freight gear puller. But it now is back to new. So, it was a success for me, but i would recommend anyone who isn't very mechanical to just send it off to Utah (again, I forgot the place, I think they talk about the shop in one of the other posts), and you will have a better than new machine.
Nov 08, 2009 | Bosch 700 Watts MUM6622 Universal Series...
I have a Sunbeam Heritage Series Mixmaster, 350 Watts, just purchased yesterday. I used it to mix cake batter, cream butter, whip egg whites....the problem is that it doesn't blend the ingredients. The...
There should be a small lever on the base in front of and below the bowl. It will move to 2 positions. It sounds like you have it set for the small bowl but are using the large bowl. Press down on the lever and move it to the other side. If I'm right, that should correct the problem.
Oct 26, 2009 | Sunbeam Heritage 2346 Stand Mixer
Mixer part not rotating
Have recently inherited an old Kenwood Major A707A with same problem, contacted local electrical repair man, experienced with Kenwood mixers. He is fitting a new clutch, will cost about £30. I think its worth it. Anyone out there know where I can get Instruction Manual ?
Aug 14, 2008 | Kenwood Food Mixers
Mixer whine
Unfortunately, the Kenmore mixer sounds louder than freight train due to a poor planetary gear design. I had to take mine back so that the neighbors wouldn't **** me. I hooked up two identical models at the store to get the same, painfully loud, experience. I think I prefer the sound of a bandsaw to the grating noise it produced.
Jan 01, 2006 | Kenmore KSM100 Stand Mixer
Bosch 400 Watts MUM4422 Compact Series Stand Mixer Logo
100 people viewed this question
Top Bosch Food Mixers Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Bosch Food Mixer Expert? Answer questions, earn points and help others
