Question about ASUS P4GE-MX Motherboard
Mosfet in my asus motherboard burnt out,
A mosfet in my asus motherboard burnt out, but the computer is performing just fine (for now) i wonder what would be the long term effect of a burnt mosfet on my cpu.
thanks!
Posted by infinity_one on
Anonymous
  • 700 Answers
Better to have the motherboard replace, do not wait until some other components might be also damage. Commonly mosfet is use in power supplies regulator. It can kill your processor and memory.
And also check your power supply. It might also having problems.
Posted on May 02, 2009
Asus pro31f laptop turns off when i go to battery
Sounds like a bad Power MOSFET on the motherboard, to me.
Using the HP Pavilion dv6000 series, and Pavilion dv9000 series of Notebook PC's; for an example,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
In so stating, do you wish to attempt board level repair, or just replace the motherboard?
Hmmm, may have to retract that one. No Service Manuals available to the public.
Of course I am a tech with years of knowledge in repairing laptops.
If you can stand a 'windy' tech, and LOTS of reading, I can guide you in disassembling.
Post back in a Comment.
(I can guide you with board level component replacement too, but you're gonna' need to sharpen your soldering/de-soldering skills.
For example; the Fairchild Semiconductor Industries - FDS6679 - Power MOSFET, runs about $1.01 USD.
The Alpha & Omega Semiconductor LTD - AO4407 - Power MOSFET, runs about 78 cents USD.
SMD/SMT components.
Surface Mount Device/Surface Mount Technology )
Regards,
joecoolvette
Feb 26, 2013 | ASUS Computer International K52f C1 156...
Ihave mbx -160 ms70 sony laptop mother board ther is no power adapter is working pleas telme whatare the comapnents i have to chek in power section
A) Check the DC Power Jack.
The DC Power Jack is the jack that the AC adapter (Charger) plugs into. (May state DC_IN near the jack on the outside of the laptop case)
IF, I have it right, there is a DC Power Harness. The DC Power Jack is connected to wires in a harness, and the harness has a plug on the end. The DC Power Harness plugs into the motherboard.
http://www.laptoppartsexpert.com/i-131440-dc-jack-w-cable.html
[Instead of the DC Power Jack being soldered to the motherboard]
Remove the DC Power Harness, and with a multimeter set to OHM's perform a continuity check of all wires in that harness.
See if the DC Power Jack of the harness, is in good shape.
DC Power Harness checks out?
Problem is with the Power MOSFET's on the motherboard, or a ceramic capacitor, or two.
!O_O!
MOSFET,
http://en.wikipedia.org/wiki/MOSFET
Power MOSFET,
http://en.wikipedia.org/wiki/Power_MOSFET
Don't know who makes the P.MOSFET's on the motherboard, or what manufacturer number they are.
They are however, located Near the connector on the motherboard for the DC Power Harness, and they have 8 J-leads.
This is an example of a Fairchild Semiconductor FDS6675BZ
Power MOSFET. One example of a P.MOSFET used in this application, on a LOT of laptops,
https://docs.google.com/viewer?a=v&q=cache:oER5NNz8cwcJ:www.fairchildsemi.com/ds/FD/FDS6675BZ.pdf+Fairchild+FDS6675BZ&hl=en&pid=bl&srcid=ADGEEShOhWPjm_M-ROHme4iEMrztCTOd-28jNiy1hVLQQh_VOyv8zcXEVDB_iTQA6MuZO88UmRkDgjyW9j4CP2aIJ-4DS-h6JNM3lvxldeApQeecmz_DADCw1s7tmNLxfPknqX14SZP6&sig=AHIEtbS_rYUAeo_8rB9YHkW05ZjLqeH4Jg
Note the leads coming off of both sides. Those are 'J-leads'.
See if any of the Power MOSFET's, or Ceramic Capacitors, are burnt, and/or bubbled.
This gives you more information, but is using HP Pavilion dv6000, and Pavilion dv9000 series of Notebook PC's, as an example,
Here you see the two Power MOSFET's used. One on top of the motherboard in the power section area, one on the bottom of the motherboard.
Looking at the second photo with the Alpha and Omega AO4407, Power MOSFET as an example, look to the right of the yellow circled AO4407.
To the right is a Ceramic Capacitor.
Rectangular in shape, and looks like there is a black wide band across the middle. There are two more above it. See if one, or more of these are burnt.
http://www.mouser.com/Search/Refine.aspx?Keyword=FDS6679
That's right. A Fairchild Semiconductor FDS6679 Power MOSFET is $1.01 USD, without tax, and shipping.
Just an example of cost.
http://www.mouser.com/Passive-Components/Capacitors/Ceramic-Capacitors/Multilayer-Ceramic-Capacitors-MLCC-SMD-SMT/_/N-b2cj?P=1z0ynasZ1z0vhw8
Scroll down. Average cost is from 9 cents to 80 cents USD.
Regards,
joecoolvette
Sep 29, 2012 | Sony A1246282A - VAIO VGN-N Series Laptop...
Asus pro31f series duoT2350 notebook does not boot up. Potential motherboard failure? How do I recover data?
A) Remove ALL power. Remove the AC adapter (Charger), and Battery.
B) Remove the Harddrive;
According to specifications it is a 100GB SATA harddrive.
Harddrives are measured across their width.
A laptop harddrive is 2.5 Inches across in width. (2 -1/2 inches)
Desktop harddrives are 3.5
Install the Asus Pro 31F harddrive in a 2.5 SATA external enclosure.
The external enclosure has a USB cable. Turns your laptop harddrive into an external harddrive.
One example of a 2.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
C) I believe what may be going on, is you have a failed Power MOSFET, or Power MOSFET's.
?O_O?
MOSFET,
Power MOSFET,
D2PAK surface mount,
http://en.wikipedia.org/wiki/D2PAK
(Requires using a clip heatsink on each lead when soldering.
After all, this uses Transistors )
Motherboard problem, yes I believe you may be correct.
Repairable? Yes.
Find a tech that can perform this? Isn't easy.
Most just want to replace motherboards.
Why? More $$$$$$$$.
(Ahem, I'm telling you about it, so I am not one of these noobs! Lol!)
Regards,
joecoolvette
Jul 30, 2012 | Computers & Internet
Processor not heating
Check 12 Volt Motherboard VRM Section, Next Checek VRM Upper Mosfet or lower Mosfet one of them may b short.
Mar 08, 2012 | ASUS P4P800-MX Motherboard
The 3.3 volt is zero in asus 945
check the voltage in the mosfet if there is voltge check the mosfet for leakage if leakage remove the mosfet with new one
Feb 14, 2012 | ASUS P5LD2 Motherboard
How to test a motherboard
All computers perform a self test upon turning on to the operating system. One beep from the speaker tells you the mother board is fine. If the motherboard is out of the computer testing is would be done by a technician although they find it easier to test it mounted in the computer
Jun 29, 2010 | ASUS A8N-LA GeForce 6150 LE Socket 939...
Motor Controller Board Schematic
If you are the original owner the parts in residential settings is lifetime so call body-solid @ 1-800-556-3113 ext 520
Feb 04, 2010 | Endurance T10HRC Light Treadmill
Dead PC, Pheonix Award Bios post code 2A, ASUS A7V400-MX SE Mothe
There is 3 reason for 2a error
Ram power supply mosfet open or short
bios programme currupt
Feb 02, 2009 | MSI Galaxy KT400 (MS-6596-20B) Motherboard
Motherbord mosfet burning frequently
repair your motherboard again then have your power supply unit replaced... there may be something wrong with your power supply output voltage..
Aug 01, 2008 | ASUS P4GE-MX Motherboard
ASUS P4GE-MX Motherboard Logo
599 people viewed this question
Top ASUS Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Roy May
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
