Motorola Mobility RAZR V3 Logo
Posted on Oct 04, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Motorola V3 GSM Phone book
When I press the down key the phone book is diplayed for a brief moment this is also the same when I enter the main menu and select phone book the display is but a brief moment. your help would be appreciated. Regards Tony Trigg 0418766527
Anonymous
Level 2:
  • Expert 72 Answers
  • Posted on Feb 15, 2008
Anonymous
Expert
Level 2:
Answers
72
Questions
Helped
18024
Points
110
You need to set the settings for your phone. just go to settings and look for the phone display settings and set the time duration for the menu to be displayed
1helpful
Cant remember my code for Master Reset and Clear what must I do
Pleas e do the following step
Code to lock keys. Press together *7
Note: [] (pause) means the * key held in until box appears.
Select phone line - (use this to write things below the provider name):
[] [] [] 0 0 8 [] 1 []
Add phonebook to main menu:
[] [] [] 1 0 5 [] 1 []
Add messages to main menu:
[] [] [] 1 0 7 [] 1 []
Copy SIM memory (phonebook menu):
[] [] [] 1 0 8 [] 1 []
Eng Field options (main menu):
[] [] [] 1 1 3 [] 1 []
Slow (Frequency of search menu):
[] [] [] 1 0 1 [] 1 []
Medium (Frequency of search menu):
[] [] [] 1 0 2 [] 1 []
Fast (Frequency of search menu):
[] [] [] 1 0 3 [] 1 []
Enable EFR:
[] [] [] 1 1 9 [] 1 []
Function :
[] [] [] # # # [] 1 []
Change pin:
[] [] [] 0 0 4 [] 1 []
Unblocking using the "puk" number:
[] [] [] 0 0 5 [] 1 []
You can change GSM frequencies to 900/1800 by entering the enginnering model.
Following the below steps:
enter menu and press 048263* quickly,
then you will enter the secret engineering menu under "Opcode"
input 10*0*3 for GSM 900
10*0*4 for GSM 1800
10*0*5 for GSM 1900
10*0*6 for dual band GSM 900/1800
10*0*7 for dual band GSM 850/1900
To add extra message space 4 your Motorola C350 C450 C550 or C650,
press menu button, press 048263* quickly, then on the popup menu enter 47 press ok.
press 50 and ok.press 1 ok.press 64 ok.press 1 ok.press 186 and ok.
You will receive an extra 50 msgs memory space.Switch phone off and back on.
Hope this helps.
Thanks for using fixya .
tip
MOTOROLA TIPS
Motorola Secret Codes
IMEI number:
*#06#
Enable EFR:
Function :
Change pin:
There are lots of similar codes exist. If you change the last number to 0 you can deactive that code. The 3 digit number at the middle are from 0 to 999. I put the most interesting codes. (EFR):Enhanced Full Rate Codec.
You can change GSM frequencies to 900/1800 by entering the enginnering model. Following the below steps:
enter menu and press 048263* quickly, then you will enter the secret engineering menu
under "Opcode"
10*0*4 for GSM 1800
10*0*5 for GSM 1900
To add extra message space 4 your Motorola C350 C450 C550 or C650, press menu button, press 048263* quickly, then on the popup menu enter 47 press ok.press 50 and ok.press 1 ok.press 64 ok.press 1 ok.press 186 and ok.You will receive an extra 50 msgs memory space.Switch phone off and back on.(not tested)
Important!
Try these codes at your own risk! We don't accept any complaints.
Some of these codes may not work
on Sep 27, 2010 • Cell Phones
tip
Motorola secret tips
Enable EFR:
Function :
Change pin:
10*0*4 for GSM 1800
10*0*5 for GSM 1900
on Mar 08, 2010 • Cell Phones
1helpful
My motorola v360 unlock code and security code has been changed and now i cont entre my phone please help?
hello,
Enable EFR:
Function :
Change pin:
10*0*4 for GSM 1800
10*0*5 for GSM 1900
Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
I need to change my voice message
1 Call your Motorola voice mail service. Press the "Contacts" or "Address Book" button and select the "Voice Mail" entry. Press the "Call" button.
2 Enter your password. Call the service provider for your Motorola phone if you cannot recall it.
3 Delete all voice mail messages. In order to access the main menu you'll be required to empty your inbox.
4 Select "Change Personal Options," then choose the "Change Voice Message" menu. Disconnect the phone call to save your settings.
8helpful
4answers
7helpful
5answers
I want to codes
LG SECRET CODES:
LG all models test mode: Type 2945#*# on the main screen.
2945*#01*# Secret menu for LG
IMEI (ALL): *#06#
IMEI and SW (LG 510): *#07#
Software version (LG B1200): *8375#
Recount cheksum (LG B1200): *6861#
Factory test (B1200): #PWR 668
Simlock menu (LG B1200): 1945#*5101#
Simlock menu (LG 510W, 5200): 2945#*5101#
Simlock menu (LG 7020, 7010): 2945#*70001#
Simlock menu (LG 500, 600): 2947#*
LG-U81XX SPECIAL CODES
Code to read phone version :
- Phone without SIM
- Enter 277634#*# or 47328545454#
- Select 'SW Ver.info'
Code to reset phone :
- Phone without SIM
- Select 'Factory Reset'
Code to enter UNLOCK MENU :
- Phone wit SIM inside
- Enter 2945#*88110#
Test Menu 8330 : 637664#*#
Test Menu 8180 V10a: 49857465454#
Test Menu 8180 V11a: 492662464663#
Test Menu 8130-8138: 47328545454#
Test Menu 8110-8120: 277634#*#
MOTOROLA SECRET CODES
On the main screen type
IMEI number:
*#06#
Enable EFR:
Function :
Change pin:
under "Opcode"
10*0*4 for GSM 1800
10*0*5 for GSM 1900
NOKIA SECRET CODES:
*#06# for checking the IMEI (International Mobile Equipment Identity).
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
*#62209526# - Display the MAC address of the WLAN adapter. This is available only in the newer devices that supports WLAN like N80
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# - Half Rate Codec activation.
*#4720* - Half Rate Codec deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
*#7328748263373738# resets security code.
Default security code is 12345
Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin#
Change closed caller group (settings >security settings>user groups) to 00000 and ure phone will sound the message tone when you are near a radar speed trap. Setting it to 500 will cause your phone 2 set off security alarms at shop exits, gr8 for practical jokes! (works with some of the Nokia phones.)
Press and hold "0" on the main screen to open wap browser.
2helpful
Reset
From thr moment I turn my phone on: middle button > 1x down > select > 5x down > select > 2x up > select > enter pin (6 zeros if you don't know it) > select > top left key
Unlock codes
here are set of code that you can apply and play with. You should have included the model of your cellphone but i'm hoping that this would help.
Enable EFR:
Function :
Change pin:
under "Opcode"
10*0*4 for GSM 1800
10*0*5 for GSM 1900
Motorola Razr
is your phonebook located on the sim or phone? brief me... tnx..
Top Motorola Mobility Cell Phones Experts
ADMIN Eric
ADMIN Eric
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
