Question about LG DH30 GoldStar Dehumidifier
How to check Some compressors have a black plastic overload under the compressor cap which could be bad.
Santa fe dehumidifier running but not producing any condensate. No ice forming on the coils and filter is clean.
You should check if the compressor is running. Your description makes it appear that the fan may be running and the compressor may not be running.
There are many things that can cause a compressor to cease running:
Open defrost thermostat
Bad run capacitor
Low refrigerant charge (caused by refrigerant leak)
Bad compressor relay
Bad compressor overload
Bad compressor motor
Other things to check:
If the fan switch is set to "on" and the humidity control is set to a high humidity level, the unit may appear to be running, but the compressor will not operate. Check the setting of your humidity control.
If the dehumidifier is operating in a room with a high temperature and a low dew point (very low relative humidity), it may be unable to remove any more moisture from the air.
If you are not comfortable troubleshooting the unit on your own, call the manufacturer service department at 1-800-533-7533, EXT 8459. They are very helpful.
Mar 05, 2011 | Santa Fe 4027450 Dehumidifier
My Santa Fe compact dehumidifier in my crawlspace makes a noise (not a smooth humming sound but more of a harsh vibrating sound) when it is not dehumidifying. I can turn the knob to the dryest setting and...
The black cylinder is the compressor. It sounds like your unit is cycling the compressor for some reason. If the compressor starts, runs fine, and removes water when you set the humidity control to the driest setting the compressor is probably OK and the problem may be with the humidity control causing the dehumidifier to "short cycle" for some reason. You may need to change the humidity control or relocate the dehumidifier in your crawl space.
If the compressor attempts to start, and then sits quiet for 10 minutes, and then attempts to start again, you have a problem with the dehumidifier. There are a few things that can cause this problem:
Bad compressor capacitor
Plugged capillary tube or broken expansion valve
are the common causes of this behavior. If you suspect one of these problems, call the factory service department at 1-800-533-7533 for help.
Good luck with your dehumidiifer.
Jan 11, 2011 | Santa Fe Advance Pre-Filter Dehumidifier
I am having Daewoo refrigerator Model DIR220. When I switch on the refrigerator the compressor starts after about 3minuites and stops in few seconds. fan motor works continuously. As the compressor stops...
the compressor has an internal overload to protect it from overheating. the compressor is cooled by the refrigerant passing over it. It could be a bad compressor,, bad charge of refrigerant, or simply dirty coils not allowing air movement
Nov 26, 2009 | Dehumidifiers
Fan kicks on but compressor does'nt start. Humidity control checked out. Compressor ohmed out. Fan runs for about a minute then it shuts down.
i would do a continutity check on you relay and overload, other than that
what is the humidity level in the room, as well as the ambiant temp. these mahines cycle for that very reason, the fan will come on, do a check and then determine if it should start the compressor.
check if you have voltage at the compressor when its supposed to be running ( just a last thought)
ive seen compressors ohm out, but in fact be bad
Oct 09, 2009 | Kenmore 54351 Dehumidifier
LG LHD30 the compressor does not cycle on
Compressor won’t Start
The Main reasons that this will happen
1 - A bad run capacitor (silver or metal capacitor)
It’s either shorted, grounded or open.
If it’s shorted a lot of times it will bulge out, (sometimes slightly)
2 - A bad start kit ( plastic capacitor and Relay connected to it )
The capacitor is either shorted or open
The relay either has an open coil between terminals #1 and #5
Or the relay is stuck.
Any time you change the capacitor or relay you should change
the other, especially if they are over a year old.
3 - A loose, burnt or disconnected wire
4 - Wired wrong
5 Compressor is open (windings burnt open)
6 Low on charge not getting enough cooling back to compressor, (Feel top of compressor to see if it’s hot it shouldn‘t be)
7 Some compressors have a black plastic overload under the compressor cap which could be bad.
Aug 07, 2009 | LG DH30 GoldStar Dehumidifier
Fan runs but copressor will not kick on
4 - Wired wrong
Jul 30, 2009 | Kenmore 53701 Dehumidifier
Compressor kicks on for about a min then shuts down overload trips out
4 - Wired wrong
Jul 29, 2009 | LG LHD45EL Dehumidifier
Compressor won't start
4 - Wired wrong
Jul 29, 2009 | Ebac BD150 Dehumidifier
Kenmore Dehumidifier
My Kenmore had the problem of the fan running, but not the compressor. The compressor overload part was bad.
Togarba
Aug 27, 2008 | Dehumidifiers
Whirlpool 50 pint dehumidifier
Lifeguard, there are generally no user accessible safety items in dehumidifiers. You are likely describing the start relay which is used to 'boost' the compressor on starting. Jumping it will not help you. It sounds like the compressor is defective. Economically, there is no justification for servicing these units unless they require refrigerant gas or if the fan motor has seized, something you can readily determine. If you don't hear the compressor hum when it should, there is no service procedure available for these sealed units.
Feb 22, 2008 | Kenmore 54501 Dehumidifier
LG DH30 GoldStar Dehumidifier Logo
Top LG Dehumidifiers Experts
Dan Webster
Dan Webster
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
