Question about Tablets & eReaders
My charger is loose so I need a USB charger where can I buy one
I need to charge my tablet but the charging cord is loose so I need a USB charging cord to charge it.
Posted by Helen Fuller on
Ashley Tennant
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 42 Answers
Try amazon if you are looking for just the cord.
Posted on Nov 11, 2013
3 Related Answers
Steve Stewart
  • 84 Answers
SOURCE: Wont charge or keep a charge
First off, a google search will show you several companies out there that will replace the cells in your existing battery for around $70. Not bad. However, you mentioned that positioning of the plug can get it to work. The solder joints can become broken from the board, and the small plug in jack will get loose after a year or two of plugging in to it.
You can get a replacement plug at fry's electronics, or many online stores. If you need a service manual, or driver disk set, you can get them at mpcdrivers.com
Posted on Apr 10, 2010
xiangxin33
  • 5 Answers
SOURCE: Gateway M1300 tablet pc will not charge in the
Will the tablet operate on the docking station (or power cord) without the battery in place?
If not, the power circuit on the tablet motherboard is broken.
online shopping
Posted on Mar 08, 2012
senate42000
Kevin
SOURCE: My VIZIO Tablet 1008 micro USB charging port is looseand charging indicator comes on some times when I move the wires around. ow do I get to charge the Vtab?
I had the same problem with my vizio tablet. The port came loose after the wife and kids kept playing with it. The tablet would not charge anymore. What I had to do was open the tablet and check if the little pins that connect the Micro USB port were still soldered on the circuit board. Mine were broken off so I had to replace the whole port. I couldnt even find the OEM replacement part so I had to buy a Mico USB (style B) port off ebay and made it work.
Posted on Jul 03, 2012
HiSense Sero 7 tablet. Why no charge, no power?
About 1,620 results (0.80 seconds) Search Results
    HQRP USB to micro USB Cable / USB Charging Cable for ...
    www.amazon.com > ... > USB Cables
    Amazon.com, Inc.
    Rating: 2.9 - ‎22 reviews
    1A AC Wall Power Charger Adapter Cord for Hisense Sero 7 LT Lite E270BSA .... If you try to use the tablet while it is being charged, no charging will take place.
    HQRP AC Adapter / Battery Charger / micro USB Charging ...
    Amazon.com, Inc.
    Rating: 3.7 - ‎6 reviews
    HQRP USB to micro USB Cable / USB Charging Cable for Hisense Sero 7 LT E270BSA / Hisense... ... HQRP Micro-USB AC Adapter rapidly charges your Cell Phone / Tablet PC ... This one does not. ... Yes No Sending feedback. ... $3.91. 1A ACWall Power Charger Adapter Cord for Hisense Sero 7 LT Lite E270BSA Tablet.
    HQRP AC Adapter Dual microUSB Charging Cable for ...
    www.amazon.com/HQRP-Adapter-microUSB-Chargin...
    Amazon.com, Inc.HQRP AC Adapter Dual microUSB Charging Cable for Hisense Sero 7 LT E270BSA... Do not wait until charging one of your devices to charge the second.
Feb 09, 2016 | Tablets & eReaders
Isnt there a charging cord i can buy to use while online to plug in
yes - it is a usb charging wire that you plug into a power point and the tablet and it powers the tablet while charging the battery
Nov 06, 2015 | Tablets & eReaders
How do you use a USB cord to charge a azpen 13.3 when the normal charging way is broke
I don't think you can. The USB port is meant to go out of the tablet and the charging port brings the charge in. Unless the Azpen is different from many other tablets.
Mar 19, 2015 | Tablets & eReaders
Charging port loose.no longer charging on my tmax tablet
Try a different Micro-USB cable. It is usually caused by the cable's micro-USB end being loose and not the tablet's charging port. Most smartphones these days use Micro-USB so you can usually try using one of those if you have one.
Aug 04, 2014 | Tablets & eReaders
We got a RULU in 12/2013. It worked for 3 months and now can not charge i
Some tablet brands will not recognize certain charger brands or connections.
First, try all available connections-USB-wall inverter, and direct computer connection (making sure the computer is awake and logged in). Second, try restarting your tablet. Third, try gently wiggling the connections on both ends, to see if it recognizes a charge. Finally, leave it plugged in for a few hours, even if it says it isn't charging. You may have a trickle charge-to put it simply, the cord is not giving the device enough power to qualify as a charge, but there is power traveling through the cord. If the charge level goes up a little over that time span, you have a trickle.
If these don't work, just purchase a new charger. They're sold everywhere-Wal-Mart, Target, Best Buy, 7-Eleven, name a store and they probably sell USB charger cords.
I hope I helped.
Jul 08, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
My NOOK HD doesn't want to charge. What do you think the problem is...just the cable or something else. Thanks in advance for your help with this problem.
Cord that plugs into Nook may be loose in port and not making a good connection. You may even want to try a different USB cord.
Aug 14, 2013 | NOOK HD 7 Tablet
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
