I have a Neptune jet tub. The motor turns on when I press on but there is NO air coming from the jets. What do I do?
SOURCE: How can I unclog plumbing in whirlpool tub used to clean dogs?
Depending on how mechanically inclined you are, take apart the tub and clean everything out. No easy task, I know, but who want old dog hair floating around? That will be your best bet.
SOURCE: Bathtub jacuzzi (motor turns runs but nothing coming from jets)
Each Jet will have an adjustment many times right on the jet nozzle. Carefully try to rotate them counter clockwise to open up the jet. This assumes you can here the motor running.
Phil
SOURCE: Only 3 of 6 jets in jacuzzi tub working
Make sure the jets themselves are fully opened. Some models you can turn individual jets on & off
SOURCE: hot tub jets stopped working
yes my jacuzzi uses air on the suction side to make bubbles. you must have clogged it. how long is tube can you slide a rod in there to check if its blocked?
SOURCE: Black come out the jets when first operating them
Didn't fully drain at the end of last year, that gunk was mold, rust and gunk that's been sitting in the piping since last year. Not really a problem just remember to take a closer look at the plumbing on your tub next year and get all of the possible places that water may hold drained completely.
