I want to use an external amp would i need a cross over before the amp to get the correct sub frequency
Usually the external amplifiers have potentiometers that you can adjust called sub sonic and LPF. Find what your sub needs to be setup to and set the LPF to that frequency, usually 40-60hz.
Find the tuning of your box or the sub sonic frequency cut-off and set it there. usually 30hz and under, this will keep your subwoofer from unloading and damaging itself.
SOURCE: i have an auto amp with no crossover for
You could go with a type of passive crossover, and that should allow you to also control gain as well as the bass input, and you can also go with a low pass filter as well. These are quite inexpensive at Wal-Mart and other places, and just run in-line with the wiring. There is no real cutomizability with the latter option, but it could be a means to get better sound while you save for a stronger crossover.
If you use the crossover to input into the first amp, you will get the same signal into the second amp.
Testimonial: "Thank you for the info. I thought thats how it would work, but wasnt sure. Thanks again"
