Clear key ® Interrupt key ® "R" key ® Interrupt key ® 16 ®
Start key
The fusing temperature goes 10 °C below or 10 °C over the stand-by
temperature after warm-up is completed.
- Possible causes -
· Thermistor defective
· Poor connection of the fusing unit
· Power supply board defective
To reset a SC564 , enter SP 5-810 (SC code reset) and select
"1". Then hold down the Photo mode key and the key at the
same time for at least 3 seconds (this does not require the main
switch to be turned off and on).
· Turn off the camera.
?· Remove the battery pack.
?· Press and hold the power button for 30 seconds.
?· Allow the camera to remain without power for 60 seconds.
?· Reinsert the battery pack.
?· Turn on the camera.
Also, try resetting the Camera back to factory default by pressing the RESET button using a sharp-pointed object. The RESET button is located at the lower right side of the control buttons.
Please make sure that the Camera is turned ON before you reset it.
Good Luck!!
