Insignia IS-PDO40922 Portable DVD Player Logo
Question about Insignia IS-PDO40922 Portable DVD Player
Insignia pd040922 battery replace
We tried charging it last night. Would not charge. Where can I get a replacement battery?
5 Related Answers
Anonymous
SOURCE: insignia dvd is-pd040922
I have the same model of DVD player and sometimes that will happen to me, and when it does I will move the screen up and down, and the picture always comes back for me, you can try this but I dont know if you have the same problem as me.
Posted on Nov 27, 2006
Shilon
Yoav Shilon
  • 104 Answers
SOURCE: Insignia PD10135 Portable DVD Player Battery won't work
It sounds like your battery is dead. Maybe yuo should consider replacing the battery in a new one.
Posted on Apr 05, 2007
Anonymous
SOURCE: Battery charge
the battery is dead. that happened to me and i had 3 choices: 1)buy a new dvd player 2)buy a new recharable battery or 3)keep the portable plugged to the wall while i watch movies. i chose number 3 because i usually just use it at places plugs are available. but yeah, the battery is dead.
Posted on Aug 29, 2007
Anonymous
  • 410 Answers
SOURCE: I have a 3 year old insignia 8
http://www.amazon.com/NS-7DPDVD-PD040922-PD101351-JE-A15-09V0A1-JEA1509V0A1/dp/B001R28LJ2
Link for AC Adapter.
http://rover.ebay.com/rover/1/711-67261-24966-0/2?ipn=psmain&icep_vectorid=263602&kwid=1&mtid=691&crlp=1_263602&icep_item_id=260544576977&itemid=260544576977
Link for Car Adapter
http://bestbuy.partsearch.com/Model/Best+Buy+Company+Incorporated/Insignia/NS8PDVD.aspx
Link for batteries.
You can do further searches and maybe get yourself some better prices. Good Luck!
Posted on Mar 21, 2010
Anonymous
SOURCE: insignia dvd travel theater (IS-PD040922) was
I am having maintaining power problems with my PD040922 when I try to use it the system clicks and goes back to LOADING option. I have tried to work through this problem by removing battery and just have mains power connection. Then I just use fully charged battery with the same problem occuring. Is there a solution, other than buying a new player?
Posted on May 25, 2010
Insignia tablet will not fully charge
With new devices, you have to go through at least 3 charge, discharge cycles, before you can see how long the battery will last. And then not all batteries are the same. Nit all users are the same. Some have to replace a battery after half a year, some can last as long as 10 years. When you have an older device, and the charge is not enough anymore, think of replacing the battery (or let it replace). You also could check what apps are all running in the background and kill off some of them. Use a system app (most are free) to check what is running for you. Better switch of GPS when you are inside, because it does add nothing and drains lots and lots of power.
Problem of charging the battery
Check battery indicator. If OK, update BIOS. If no change, check battery bios info, if AC Adapter is incorrect, replaces it. Please comment if the information provided has been helpful for the improvement of my support assistance. Thank you and regards.
2answers
I have a 3 year old insignia 8" portable dvd player, NS-8PDVDA. I have not used it in 2 years and never charged the battery. It is dead. Is there anything I can do? Do I need to replace the battery? If so,...
Link for batteries.
2helpful
Insignia dvd travel theater (IS-PD040922) was
2helpful
2answers
Acer 5315 Battery cHarging Problems
All rechargeable batteries have a limited life, and as they age their charge capacity reduces over time and you get shorter and shorter time between charges.
Recharage batteries have a finite number of charge and discharge cycles and batteries over 2 years old are considered nearly worn out. Worn out batteries won't charge up at all.
The player won't turn on.
Hey illinifansx5,
Have you tried plugging in the unit to your PC and then pressing the reset button for 5 seconds?
Also, try removing the battery for 30 seconds, then replace and attempt to charge.
If these options don't work, it may be a hardware or battery failure and you should try to return it.
1helpful
2answers
I have the same unit, and had the same problem numerous times. I finally removed the battery and sprayed CRC electronic cleaner over the battery terminals as well as the units terminals. Put the battery back in hooked up the charger and it went green. It is playing as I write this.
2answers
Insignia IS-PD040922 portable dvd player
The batteries are not being charge,it might be bacuse you have the wrong ac adapter,you should get the original to start then let the batterys charge for at least 5 hours or until the red light stopr blinking.You can find more inf.here http://www.insignia-products.com/p-31-insignia-7-169-widescreen-portable-dvd-player.aspx
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
