The oven fan is making a loud noise. Even when we preheat it immediately starts. It doesn't sound like the blade is hitting anything but it does sound louder than usual and starts immediately, even with a low temperature selected, and does not stop until well after the oven has been turned off. It started after I broiled something on High for 5 minutes. Today, I baked something at 350 and it turned on immediately again.
SOURCE: propane coversion of kenmore 790 gas range
Most gas stoves are shipped for natural gas .You need to check the orifice on each burner to see if they are for natural gas or propane.If you ordered propane the stove should have been shipped with the orifices.They may be in a bag with your stove documents.
tk46
SOURCE: Kenmore Oven - neither the bake or broil work, dial doesn't light
these elements burn out over time so chk. that out
SOURCE: Kenmore Electric Range model 790 has F9 & F1 code error
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
SOURCE: Oven will not heat
Since bake and broil use different elements, and it is unlikely both went out at once, and then I would suspect the switch instead of the elements.
SOURCE: kenmore gas range will not stop beeping showing F9 in window
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%^
What is the model number of your unit?
