Televison & Video Logo
Mike Sands Posted on Nov 09, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Remote I have a Samsung cable box by time warner cable
Level 3:
Top Expert:
  • Philips Master 76,851 Answers
  • Posted on Nov 10, 2013
Philips Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14987242
Points
237762
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check out, which brand remote control has setup codes to your TV/Device brand. Setup code list & setup procedure to some popular brand remote controls are given. Check it, and determine which brand remote control should be bought, and buy that brand remote control, according to availability. If you wish to get more details, check the sites linked here. Set-up code list, and Set-up procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name of your TV / Device, in the search box at the top right of the display window.
I'm trying to program a magnavox converter box with a universal remote model UR5U-8780L-TWT. I need the code for this please.
Hi Jerry, This is from the link below.........
The Time Warner Cable CLIKR-5 is designed to offer complete control for all digital, HD and DVR set-top boxes. The UR5U-8780L is factory programmed to operate Scientific Atlanta/Cisco and Samsung set-top boxes while the UR5U-8790L is factory programmed for Motorola set-top boxes.
Time Warner Cable CLIKR 5 Universal Remote Control
Remote codes
U get that info from Time Warner - you are using their equipment and paying them big bucks for lousy service so try to get some of your money's worth outta them.
I have the urc-4330b03 big easy remote and need the code for my time warner cbl box.
Please check with the following link and key in your device details :
.http://www.timewarnercable.com/en/support/program-your-remote.html http://www.timewarnercable.com/en/support/program-your-remote.html
2helpful
Setup universal remote
Have you tried these codes: 51376, 51877 or 52187 (for the Time Warner STB) ...
2answers
Need a code for the Samsung Sound Bar model HW-C450 with the Time Warner CLIKR-5 remote model URSU-8780L-TWK
I need the codes for my samsung sound bar system using timewarner remote in san diego.
1helpful
Unable to find code for time warner cable on the innovage Jumbo universal remote
I recommend using the code-search function of the Innovage Jumbo Remote for both CABLE and SAT to try and find the one that works with your Time-Warner cable box.
To have the remote try each CABLE or SAT code it knows one at a time, follow these steps:
  1. Turn on your cable box.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the CABLE or SAT button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the cable box turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the cable box turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
1helpful
I just bought a 52 inch samsung my volume does not work on my cable remote.everything else works ok i have to use remote for the tv to adjust the volume. i have time warner
Did you try another time warner remote if yes then this is normal because if on/off works that means the volume function is not coded for the time warner remote because the set is to new.
2answers
Program Time Warner Remote RT-U62CP-1.17 to work ONKYO TX-SR575
i bot a new tv i don't have the book for the time warner remote so i don't know how to program it to work the tv it only works cable box
where can i find how to program remote that comes with time warner cable
Programming remote control to Cable TV Box
What you need to do is contact the manufacturer of either your remote control otherwise the manufacturer of the Time Warner [aka: cable providers some times also have the info on file for their customers] they store the code information within their internal systems for their customers such as yourself. Otherwise there is normally a paper insert with the remote control or the Time Warner that would list the info for select manufacturers on there. Toshiba has pretty universal IR signals/codes so you should be okay when trying to program in the codes. The manufacturers can also assist you through the steps--believe me it can get frustrating some times!
2answers
Device code for Samsung SMT-H3050 HD Cable Box
I use an old universal onkyo remote. 0035 Is a Panasonic code but worked the smt-h3050
Hope this helps
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
