The E90 error code is not a common error but it may occur when the washing machine electronics get wet for some reason. This may happen if wet clothes are left in the washer for a prolonged period after the wash cycle ends or if the same load is washed repeatedly.
Read more: http://www.ehow.com/info_12017619_frigidaire-e90-error.html#ixzz2kK4eIkIS
SOURCE: Electrolux 1087 E90
When the washing machine is turned on... it beeps and displays error message E90 it wont operate.
what can i do ?
SOURCE: hi zanussi fjr 1254 w error code e90 what does
This error code seems to be the control board detecting a wrong
configuration (in other words, an illogical set of sensing conditions,
from its connected sensors and wiring). It apparently can happen, when
wires become badly contacting, or if contaminated with motor brush
carbon (the horrible black powder that comes off the motor commutator
and brushes), or corroded from other contaminants from the soap
dispenser area. You should be able to check this, remove, clean and
replace the contacts:
Thanks
