Depends on the buzzing noise. If it's the sound of a "end of cycle" buzzer, then it could be a few things. Check to be sure door switch isn't broke and that the drum inside still turns with some resistance (not to hard, but not to easy either). You might have a timer issue, which the contacts are stuck in the off position, a start switch that might be stuck in position, a motor issue, all the way up to a wiring problem. Try tapping on the start button a couple times, rotating the timer switch for a few minutes, turning the drum a few times to see if you can shake it loose. If not, you will have to take the console back off and see if there is a tech sheet in there. Can follow the wiring and timing charts to narrow down the problem.
