I want to remove password on my emtec flash drive 8gb there is no access without password wather the disk is empty what should i do?
SOURCE: Bought a maxell 8gb usb flash drive. When I try to...
By trying to use it I take that to mean you go to My Computer and select the drive you believe it to be.
Try going to My Computer with the flash drive unplugged and then plug it in while watching My Computer for a new drive letter to appear. That will be the one to use.
If you select the wrong one you will get the message you are experiencing.
SOURCE: i have a TDK 8GB
Hello and Good Day!
Maybe this will help,first click start button located in the lower left corner of your desktop then click My computer, at the my computer window locate your flash drive perhaps it is labeled as TDK or removable drive then right click using your mouse,look the word "format" left click at the lower part of the window you'll see quick format click the box then click start.
Hope it helps
Thank you
SOURCE: My 8Gb Tevion USB drive shows No Media
Try this , it has worked freat on my drives
Super Stick Recovery Tool V1.0.2.19.rar
http://www.mediafire.com/?81t60ysdvquymsq
It is true that locking mobile storage devices, such as USB drives, with Imation Lock is an excellent way to protect your data.
However, using Imation Lock with a Kingston USB drive can create problems.
Learn how to unlock your Kingston USB drive so you can use it once again.
Ensure that your Kingston USB drive has been removed from your computer's USB port.
Start the Imation Lock software by double clicking the Imation Lock.
Plug in the Kingston USB into a USB port immediately after the "Please Insert the Device or Run This Utility as Privileged User" message appears.
Access your Kingston USB drive by clicking Start > Computer.
Double click on the device.
Start the Imation Lock software again by double clicking the Imation Lock.
Disable the password protection by clicking the open lock icon.
or
If you have password protected a USB drive or partition on your computer and have since forgotten the password, you will need to completely erase the drive.
Erasing and reformatting the drive will remove any password protection, software and data on the drive preventing you from accessing the drive.
The process is simple using Window's Disk Management utility.
Log into the computer as the administrator.
Open the Windows Start menu, select "Run," type "Compmgmt.msc" and click "OK." In Windows Vista and Windows 7, simply type the command into the "Search" field.
Select "Disk Management."
Locate the password-protected drive.
Right-click it and select "Delete." Confirm the action.
The drive will be erased and become unallocated free space.
Hope this helps.
