Hi, I was wondering how to clean my washing machine. It leaves stuff on my clothes after washes, it smells a bit, and I think there is water underneath the tub drum thing... Also, is there a filter I should empty or clean? Thanks!
Wonderful product on the market called "Affresh" comes in a tablet form. Place one tablet in the basket, and start the "hottest" and "longest" cycle and let it run. Be sure to leave the lid open or up when not in use, and be sure to keep that boot clean. The filter should be removed and cleaned "they say" every 3-5 months, but I tell my customers it depends on how you use and take care of the machine. If you forget to clean your pockets, get coins or pens, or use "smaller" items of clothes without a garment bag, then check more often. Also if you have small or very young children, check more often. Easy way to tell, pull out filter (watch for the water), and see whats in it. If it has a bunch of stuff, check it more often, nothing in it, maybe once a year.
SOURCE: Bosch Nexxt dryer WTMC6300US won't start;
For some reason my display showed the ''key'' icon. I must have switched it to lock somehow...I went through the menu,switched it to off and everything works now! Hope this helps
SOURCE: When the dryer is running it smells like charcol ligher fluid
Sometime recently there has been a petroleum product used in the house. Possibly an oil based paint, stain, varnish, adhesive or some form of cleaning product.
Anyone of these products or many others like them, contain a distillate of liquid. Check around the house.
Until that oil based product dries or cures, the odor and vapors will remain and so will the dryer smell.
At the end of the drying cycle, use the air fluff cycle to purge out the smell. Besure to return the selector on the dryer back to it's prior postition.
SOURCE: Smell after drying
Try drying your clothes without the dryer sheet and see if the smell is still there. If it is not, then the problem is the dryer sheet.
If it is, then you need to describe the smell better. Different people handle smells differently. What smells musty to you may smell fragrant to others.
You need to determine if the smell you don't like is really a musty smell, or is it a fragrance you don't like. Have some friends (not family members) smell the clothes and verify if what you are smelling is musty or fragrant.
It could also be that even though the clothes smell OK out of the washer, that the detergent you are using is the cause.
