T-Mobile Sidekick II Logo
A
Anonymous Posted on Nov 09, 2013
Sidekick slide wont turn on - T-Mobile Sidekick II
Sidekick slide wont charge the light wont shine
There was a known power issue with the Sidekick Slide. Motorola recognized the issue and say the fix was creating extra bumpers to keep the battery from sliding around. You may have one that does not have the extra bumpers and therefore your battery contact is weak.
First, make sure you are using a Motorola brand charger. No other chargers work with Motorola phones, even the cheapy ones from gas stations that claim they do. I would then check to make sure the battery is not swollen. If the battery is swollen, it is bad and needs to be replaced. Next, check to see if the phone has any water damage. Under the battery there is a white dot that turns pink/red if it comes in contact with moisture.
If none of the scenarios above fix your problem, I would suggest doing a warranty exchange.
My sidekick slide cant read my new sim..........i need help...when ever i try am stuck at the sim center.
Hi, First request the phone's IMEI code by contacting customer service for T-Mobile. If you've been a customer long enough, T-Mobile may send the IMEI code, or the code identifying the specific phone, in a few days.Turn off the Sidekick Slide. Remove T-Mobile's SIM card, which is located near the battery. Insert the new provider's SIM card.Turn the Sidekick Slide back on. The phone will detect the new code and ask for the IMEI code. Enter the code. Now the Sidekick will operate using the new network.
Thank you
2answers
My screen wont slide
ummm well a sidekicks not supposed to slide unless its the new one but what ur supposed to do is take ur thumb and flick the left and corner after ur thumbs on it though of cousre and it will open
2answers
My screen on my sidekick slide wont slide smoothly
ur bolts are loose u will need to get it fix and u will need to not flip it alot that is wat causes it
1helpful
My sidekick has very low batterty it wont turn on but can i fix it doing something else by holding the w key
no u if its really low charge for at leats about 4 to 5 hours and see if nt take it to be repaired
Help
You need to put a memory card in before you can connect your SideKick Slide to the computer.
So once you put in that Memory card, you can connect it to your computer.
3answers
Sidekick wont turn on
If you can, try a friends battery, either from a sidekick ID or sidekick 3. The Sidekick ID seems to be having the same issue as the sidekick 3 whefre the charging port goes bad. The best worka round for that is to get a charginfg cradel that has a spare battery slot.
http://repairmysidekick.org/SideKick-Repair-Parts/Sidekick-3-Spare-Battery-Charger
Top T-Mobile Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
john h
ADMIN Andrew
ADMIN Andrew
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
