Question about Olympus VN-3100PC Digital Voice Recorder
Olympus VN-3100PC drivers for Vista x64
Does anyone know how to fool Vista x64 to recognize drivers for the VN 3100PC Digital Wave Player update 2.1.4?
Posted by travelmw on
  • Anonymous May 04, 2009
    Vn-3100PC will not transfer files with a Vista 64-bit environment, rendering this product mostly useless for DVR use.
Anonymous
    President:
  • 919 Answers
Unfortunately there is no way to make this recorder compatible to Vista 64 bit operating system. You may want to call Olympus customer service and see if they can do an exchange to a VN-3200PC or a VN-5200PC as these recorders are both compatible to that operating system. Their telephone number is 800-622-6372 option 2 and then option 3.
Posted on May 04, 2009
Anonymous
We ended up getting Olympus VN-3200PC but it does not have the digital wave player CD. It downloads to Media Player. Can this download to Digital Wave Player. Our system sends directly to express dictate from DWP. It looks the same but came with no DWP software.
Posted on Sep 19, 2009
Drivers for olympus digital player vn-3100pc
Digital Wave Player (2.0):
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
After unzipping the file, click on the SETUP.EXE file to begin installation.
Download update: http://olympusamerica.com/files/DWPUP2EN.zip
Download update 2.1.3: http://olympusamerica.com/files/DWPUP4EN.zip
Do not have recorder connected until all software installed and then reboot computer. Once computer rebooted then connect the recorder.
Jun 24, 2009 | Olympus VN-3100PC Digital Voice Recorder
Need to locate a Driver for digital recorder
There are many steps in installing Digital Wave Player on VISTA 32 bit operating systems only, it is important to follow every step since installing Digital Wave Player on VISTA is dependent on this process.
Install a VN recorder on VISTA
1. Make sure the device has been uninstalled in device manager
2. Make sure the old version of digital wave player is uninstalled.
{Delete Temp files in Internet Explorer --Tools--Internet Options --Delete Files-- Delete offline content--OK}
3. Install digital wave player (The newest Version).
4. Install the 2.1.4 vista update
http://olympusamerica.com/cpg_section/software_results.asp?id=1291&os=w
5. Restart the computer.
6. Plug in the VN recorder to the USB port and turn the recorder on.
"Found new hardware" will appear,
7. install automatically.
This may fail, if you see VNUSB device, skip the final steps and proceed to Digital Wave Player to Download files from the Digital Voice Recorder.
If you will see "Other devices" listed in Device manager with "digital voice recorder" underneath it.
8. Right click on the "digital voice recorder"
9. Select update driver from the pop up menu.
10. Choose the browse computer Option
11. In the next window browse to the location that you downloaded the Digital Wave Player application to
12. Click Next
A security warning window will open,
13. Choose "install anyway" and the device will install.
When successfully installed you will see the "other devices" disappear and a VNUSB device with a "VN series device"
underneath it appear at the bottom of the device manager list. There will be a blue question mark next to the device. At this point you can close the device manager and the properties window and open Digital Wave Player. You will see the recorder listed underneath the recorder folder and be able to download and use the program normally now.
Mar 19, 2009 | Olympus VN-3100PC Digital Voice Recorder
Olympus VN-3100 software
Call tech support at Olympus. They maybe able to help you with a special link.
Feb 06, 2009 | Olympus VN-3100PC Digital Voice Recorder
Need vista driver for olympus vn3100pc
There are many steps in installing Digital Wave Player on VISTA, it is important to follow every step since installing Digital Wave Player on VISTA is dependent on this process.
12. Click Next
Jan 18, 2009 | Olympus VN-3100PC Digital Voice Recorder
Vista and CD's
This is the info off their site regarding their vista update. It has worked on my new laptop.
However, the VN-3100PC is not compatible with anything that runs 64 bit.The following is the url and the info regarding Vista Compatibility.
<Best to all>
http://www.olympusamerica.com/cpg_section/cpg_support_downloads.asp?id=1272&os=w
This download updates the Digital Wave Player software bundled with Olympus VN-*PC series digital voice recorders from version 2.1.1 to 2.1.4. It enables Digital Wave Player versions 2.0 and later to run on Windows Vista systems
Oct 17, 2008 | Olympus VN-3100PC Digital Voice Recorder
Here is the download instructions for the VN recorder software it work with the VN 240Pc up to the VN 4100PC and Widows 2000 - VISTA.
Digital Wave Player (2.1): is available via download as a courtesy, please follow the instructions below:
Jun 23, 2008 | Olympus VN-3100PC Digital Voice Recorder
Transferring files to CD
Just use the Cable u got with it, also u will need the installation cd for it...!!!
Feb 15, 2008 | Olympus VN-3100PC Digital Voice Recorder
Unable to transfer folders from the recorder to the pc
I am using Digital Wave Player software together with VN-3100PC on Windows XP, it has a limiting functionality, but it works
Oct 20, 2007 | Olympus VN-3100PC Digital Voice Recorder
Olympus VN-3100PC Digital Voice Recorder Logo
1,703 people viewed this question
Top Olympus Audio Players & Recorders Experts
Ekse
Lee Hodgson
Lee Hodgson
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
