Bose Acoustic Wave music system II - Graphite Gray Logo
Peggy Pirtle Posted on Nov 09, 2013
CD's not playable, why?
I have tried everything from unplugging to new CD's and still I keep getting NOT PLAYABLE! This unit is Brand New and have this problem from day 1. I am recording CD's from iTunes Music Library, Cd's made play in car on computer but not the Acoustic System, why?
andel jackson
Level 1:
  • Contributor 34 Answers
  • Posted on Nov 09, 2013
andel  jackson
Contributor
Level 1:
Answers
34
Questions
Helped
8734
Points
51
Try a lens cleaner cd also double check your cd for damages or you format (data type)
1 Related Answer
Sidharth
  • 41 Answers
  • Posted on Oct 10, 2012
SOURCE: there is no sound coming out of wave 3 music system, while playing CD , FM, AUX in. How to fix the issue ?
I have a similar as gift, big size remote, you havent mentioned that whether ur using an adapter 110volts or else it still would have worked but would short circuit after some use.
1helpful
How do i get my th-a9r to play dvd-rw
You can't. The Laser will only Play +R & +RW.
Non-playable discs
• DVD-ROM • DVD-RAM • DVD-R • DVD-RW
• CD-R* • CD-ROM • PHOTO CD • CD-RW*
* Audio formatted CD-R and CD-RW can be played.
• Playing back discs list as "Non-playable discs" above may
generate noise and damage speakers.
2helpful
CD not playable
call bose for repair on this unit. The laser could be dirty but in most cases there is another failure. Possibly in the motor control circuit. They have a flat rate repair service.
9helpful
CD not playable
Hello
It sounds to me like the laser lens itself may be damaged or even broken.
Here is something you can try though, this might just work if the laser lens has some dust particles stuck to it. Just go to your nearest cd shop and buy yourself a laser lens cleaner disc, it is cheap.
Follow the instructions, and if the laser lens itself was dirty, this will help, otherwise the laser lens might be broken, which is a ver common problem, cause you used it for three years now.
Hope this can steer you in the right direction.
Kind regards
Andrea
2answers
Console tipped over and Scratched Game
common, take the game to GameCrazy. They have an insane machine that cleans scratches. For $2 they will get rid of 98% of the scratch making it playable.
5helpful
CD player says CD (and I've tried a few) is not playable
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more.
13helpful
2answers
Bose Wave Music System - CD Says "Not Playable"
I turned mine upside down pressed play and it started working.
Turned it back over and it's working fine.
Non-playable disc
the unit needs to be repaired. i have the same unit. the laser(s) are only good for so many hours of use. pioneer usa can fix that for about $200.00 NOT INCLUDING SHPPING AND HANDLING. and that solved my problem. if the monitor in/out motor hasn't stopped working yet, that will come as well. they have gears that become loose and need to be replaced with new ones that i lucked out and was still under warranty for. (NOT INCLUDING SHIPPING AND HANDLING).
1helpful
3answers
Bose Wave AWRCC2 CD "not playable"
I had the same problem yesterday on my new Bose Wave Music System. I just kept on pressing reinsert everytime the CD got rejected and suddenly it started accepting CD's again.
CD changer eats CDs
Sounds like its time to take the cover off (after unplugging the unit of course). Sorry to hear you are having a problem. Good luck.
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
