Once again, the older equipment seems to have quit working for no apparent reason. We have a component Sony stereo sytem. Receiver is model # STR-D590, dual cassette player is a TC-WR59. System also includes a turntable (for all that good stuff from the 60s and 70s). For several years, we made tapes from the LPs and other cassettes with no problem. With the advent of CDs, we also recorded some of those. Last year we purchased a Sony CD recorder, Model # RCD-W500C so that we could transfer the music from the LPs and cassettes onto music CDs. In the process, I discovered that I can copy LPs or individual tracks from other CDs onto the blank CDs with no problem. However, when I tried to copy a track from a cassette onto the CD, nothing happened. I then tried to copy cassette tracks onto a blank cassette, but nothing would copy. So the situation now is that I can copy LP music and CD tracks onto a blank cassette or music CD, but I can't copy a cassette track onto either type of media. Music that is already on a cassette plays just fine, it just can't be copied onto anything else. So I'm trying to figure out whether the CD player is broken or the receiver isn't working.
There are 2 long switches, maybe 4" long, called record/play switches. These can certainly cause this. Try cleaning them with the power unplugged. You would turn the cassette deck on end, so the switches are vertical. Use LPS-1 or LPS-2, and spray a very small amount in the end. Work the switch back and forth and see if that helps. Good luck.
If the turntable's cartridge/needle are "magnetic", you need an amplifier with a "PHONO" input. Most new amplifiers do NOT have one, as that stopped when CDs began replacing LPs decades ago. Since the reemergence of LPs, some expensive amps have added a PHONO input again. Only really cheap turntables have CERAMIC cartridge/needles (usually under $100), which work fine with any amplifier input but are of a much lower quality than magnetic. Places like Radio Shack and The Source sell inexpensive Pre-amplifiers for this task of increasing the sound level and correcting the frequency response to RIAA standards. The latest turntable I bought had a Preamplifier built in plus a USB connection for converting LPs to Digital.
I don't know this particular machine but here are some general comments.
Most CD recorders need you to press (and sometimes hold) the record button followed by the play button before tehy actually record anything (if you don't press the play button you will still hear sound via headphones etc. but no recording file will be created)
Does it record from vinyl records okay or is it just cassettes?
Are you using the correct sort of CD?
We use a Denon CD recorder and it only works with AUDIO CDs - computer data CDs or CDRWs will not work in it.
Even if the Crossley will accept computer CDs it may require a particular format either +ve or -ve (labelled CDR+ or CDR-) to be compatible.
Once you have tried finalising a disk and it has failed you cannot use the same disk again.
I had the same problem, but the reason for it seemed to be that the USB cable from the cassette deck wasn't plugged directly into my computer, but via a hub. When I plugged the cable directly into my computer (PC, using Windows XP), the problem disappeared, or seems to have disappeared so far.
I turned it off for two (2) hours - turned it on and it worked. Apparently this unit overheats after one session: one (1) cd-r per session then shut-down.
It is worth it, when it works, because my lps have no hiss when finalized.
I did hook up my PC to my SA-203 successfully. I noticed the amplification was weakest when I hooked up through the "phono" connection but in all cases both speakers worked. Be certain you have plugged in the cables completely and the contact points are clean. If you open your Technics SA-203 you will see it is apparently not very complicated so if the connections are the problem you can probably even fix it yourself. Go to Radio Shack online as it is unlikely the sales help knows s**t about there electronics part bins and probably neither will the manager. But once again, I really believe you just need to fiddle with the plug at the "phones" connection on your receiver. Good Luck and sorry I took so long.
Hi, I am brand new to this site. So I may not be very good. However your prob sounds like one I had a few years back. I solved mine by using two pencils, one in each hub.
Then winding manually from one to the other. This is quite time consuming, but it worked for me. Hope this helps, if not, sorry for wasting your time.
Have you taken a look at the edge of the tape? tracks 1 and 2 on a cassette are usually next to the edge and you may have a bad batch of tapes that have the edge damaged.
Another possible but not a likley problem might be the tape is out of spec. for the width, and your heads MAY have a little wear from use, and are trying to act like tape guides. If the tape is slightly wider than the grove worn in the head, the tape would be lifted at the edge and not make contact to the head.
It is not electronic as you have diagnosed this with other tapes.
Give it a try and see!
