Question about Crate Music
Crate GX 40- C schematic
This amp has a 60 cycle hum and lost some of its low end frequency
tednugentlives
    New Friend:
  • 28 Answers
Power supply capacitors failed. This is a common problem with 1990's crates, also the power on "POP".
Posted on May 02, 2019
5 Related Answers
Anonymous
  • 192 Answers
SOURCE: amps broken need to fix it
Their may be a schematic on the inside of the amp.I don't remember if Crate puts one or not. And I have had several Crate amps. never needed repair except for tube replacement. If there is not one in side , go here and find what you need . http://www.crateamps.com/support/warranty/ Good luck DFD please rate me TK U
Posted on Apr 19, 2009
Anonymous
  • 73 Answers
SOURCE: Distortion stoped working on my amp
Hi there. Sounds like the distortion foot switch is stuck. Try a shot of WD-40 where the button goes into the switch and then click it on and off a bunch of times.
Thanks
Paul
Posted on Jul 11, 2009
Anonymous
  • 157 Answers
SOURCE: Crate GX-20M burned resistor + popped cap values?
go to
http://www.crateamps.com/support/index.php
you may find what you are looking for there.
Posted on Aug 20, 2009
Anonymous
  • 1469 Answers
SOURCE: Crate GTX-30 Guitar Amp Schematic... The thing
Hi. use this link to check for the schematics.
crateamps.com/support/discontinued.php
or
music-electronics-forum.com/sitemap/f-60.html.
take care.
Posted on May 31, 2010
Fred Yearian
  • 5603 Answers
SOURCE: CRATE GX- 212 HUMS WHEN TURNED ON AND CHIRPS WHEN
Witth an oscilloscope analyze the ripple voltage across C67, C70, C14, and C12. Pay close attention to the last two of these which are on +/- 15 volt lines.
The "chirp" when shutting down is LIKELY normal and would probably be from teh DSP effects unit as it goes down. The voltages go out of the operating range and the device essentially goes nuts for a second or so.
Posted on Sep 16, 2010
Need amp schematic for a Crate model vc6112
Web page with schematics and requests:
http://music-electronics-forum.com/t26486/
http://music-electronics-forum.com/attachments/15279d1315547654-crate-vc6112.pdf
http://music-electronics-forum.com/t16609/
http://music-electronics-forum.com/attachments/7268d1260872380-crate_vc6112_271pwa_5.pdf
http://music-electronics-forum.com/attachments/7269d1260872394-crate_vc6112_271sch_5.pdf
http://music-electronics-forum.com/sitemap/f-60.html
User guide at link below from 1998 has mailing address in St. Louis.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwit2JO06LbZAhVG2GMKHflPAxEQFgg4MAI&url=http%3A%2F%2Fpdfstream.manualsonline.com%2F6%2F6d0e7f56-c06e-40bc-9925-bb1c66338de7.pdf&usg=AOvVaw1Qy5Pze8vKekErxgjmMg0U
Crate VC 6112 Owner Manual
Feb 21, 2018 | Crate Music
How to fix the input plug on a Crate GX-15 guitar amp.
If u can bend the 2 prongs back towards plug end it. Will work on prong rides on tip of it the second rides in between the to nylon rings on it if that doesn't work any radio shack carry it for about 1-2 dollars
Jan 02, 2015 | Crate Music
My Marshall Haze 40 Amp started making a very loud humming noise after a couple hours of playing.I let it cool down,and turned it back on and the noise came back after a few minutes
may be one of the electrolytic capacitors in the power supply has become leaky...this is a common problem among amplifiers...so you let it cool down..then after a period of time the capacitor heats up and then causes the hum...the power supply caps filter out the 60 hertz ac line noise...which is probably the frequency of the sound it is making...this is a good indication of these caps going bad....another thing you can check is to see if the amp is properly grounded(eg: the ground pin on the plug is present) and that you dont have an open cord or input
Jul 10, 2011 | Marshall Amplification Marshall Haze 40...
CRATE GX- 212 HUMS WHEN TURNED ON AND CHIRPS WHEN SHUT OFF. NEED SCHEMATIC AND ADVICE TO ISOLATE THE BAD CAP IN WHICH CIRCUIT THAT IT IS OSCILLATING.
Sep 16, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Crate GTX-30 Guitar Amp Schematic... The thing blew, and I need to replace two components...
or
take care.
May 31, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Thanks
Paul
May 28, 2009 | Music
Amps broken need to fix it
Apr 18, 2009 | Crate Music
Looking for a circuit board manual or diagram for a crate mx120r guitar amp
You can try Loud Technologies @ 866-858-5832, [email protected]
They hooked me up with parts and schematic for my Crate G212XL.
Apr 18, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Music Logo
179 people viewed this question
Top Crate Music Experts
Ngoro
ray gallant
Are you a Crate Music Expert? Answer questions, earn points and help others
