Question about Video Cameras
WHITE PICTURES AT NIGHT
My camera takes white pictures at night and i dont know how to fix it. I've tried every setting and nothing works. It takes beautiful pictures during the day.. and recently it has been having pictures that come up either missing or corrupted..?
Posted by beth welles on
Fred Altmann
  • 26 Answers
Seems to me you are in stop action mode where camera takes one picture every x minutes. I need your settings to give better verdict. Fred
Posted on Nov 09, 2013
Testimonial: "I HAVE THE SENSITIVITY SET ON HIGH NOW THAT ITS COLD AND RAINY.AND THE INTERVAL IS SET ON 3. BUT I HAVE TRIED EVERY SETTING AND ITS STILL GIVING ME WHITE PICS AT NIGHT"
Brad Broon
    New Friend:
Mask some of the IR LED window surface area. When I attempted to take nighttime indoor pics, they were all white. I covered ~ 75% of the led window and solved the issue.
Posted on Mar 11, 2014
  • Jim Mcgannon
    Jim Mcgannon Jun 09, 2014
    I did the same thing with a stealth cam and it worked also.
What setting is best for taking pictures at night(?)
IR/ night vision, Black and white also seem to work good most of the time too. Just keep playing around until you find one that suites your needs. Happy refraction !!!!.
Apr 03, 2015 | Vivitar ViviCam 5385 Digital Camera
TAKING NIGHT SUNSET PICTURES
this is becouse your not setting the "white balance"
up in the camera first,,,some digital cameras have a manual set up for "white balance" what the camera is doing is trying to put the color cast thats in a sun set right so it looks like day light,,,and you wont that color cast in the pitcher to give it that feeling,,,unless you over ride this white balance you will never get the color you are after,,, i use 35 mm film for sun sets
it will wip a digital camera every time here,,
but its horses for corses,good luck with your sun sets,,, but over ride that white balance first if you can
Nov 16, 2009 | Kodak EasyShare Z712 Digital Camera
Taking photos with casio ex-s10 goes all white
It don't work shutter. You need in repair lens unit.
May 16, 2009 | Casio Exilim EX-S500 Digital Camera
So much light on picture
Hi, Mark here see if I can help.
Sound like your camera is set to night photography.
Try resetting it to Auto or sports when shooting in daylight.
Hope this fixed ya! need more help comment back.
Please rate. Good Luck!
Mar 28, 2009 | Canon PowerShot A450 Digital Camera
My camera is a PowerShot A460. It can take pictures but all white
It looks like you took pictures on Manual mode and didn’t set the Exposure Compensation and Shutter speed properly. If you can get good pictures on Auto mode, your camera is ok.
Mar 23, 2009 | Canon PowerShot A75 Digital Camera
Pictures are red during the day.
U might need to change the mode in which u are taking the pics. Try setting it to Auto mode.
Mar 18, 2008 | Samsung Digimax D53 Digital Camera
Blurry white image when pics are taken during broad daylight
Try first to reset your camera. Press the menu button, go over to setup, go down to reset, press the right arrow, highlight reset and press set. Don't worry it won't erase any of the pictures on your memory card. If that doesn't work you can try and manually set the white balance on your camera and I would recommend sending it into repairs if that doesn't work since it's taking nighttime pictures fine. :)
Dec 07, 2007 | Casio Exilim EX-Z55 Digital Camera
My Canon Powershot SD630
What do pictures taken at night/poor light look like ?? if they are an improvment ,
your Exposure/Auto-Light/White Balance settings may be horribly configured.
Firstly I'd try Resetting the camera to default settings by using the settings menu .
>Menu >Settings >Reset default settings
This should eliminate poor settings as a suspect for the problem.
Sep 28, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Every picture I take is whited out
A bright LCD usually means no signal to the LCD - a loose connector. A temporary fix is to tap it - if you're lucky the connector will reconnect. The long term fix is to disassemble and reattach it. It's a $50 job by an independent shop. Let me know if I can help [email protected]
Dec 22, 2006 | Sony Cyber-Shot DSC-F717 Digital Camera
White Screen
I have Fuji FinePix 2650 Digital camera with same problem. I can almost guarantee this is not a firmware problem. I went mountain biking a few months ago and take pictures. I take out camera and turn on. I get lines then white screen. I banged on camera and fixed it. Later a few weeks ago I turn it on and white screen. i beat this thing and get bad menu selection screen for a moment then white again. It takes pictures well and talk to computer no problem but no LCD picture. I thinking it is loose connection for LCD. Send it for repair or if you seek adventure try to fix it yourself!
Nov 12, 2006 | Fuji FinePix S5000 Digital Camera
Video Cameras Logo
789 people viewed this question
Top Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
