Dell Latitude E5420 Notebook Logo
A
Anonymous Posted on Nov 09, 2013
Dell E5420 bios chip location on motherboard\
Michael Gray
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
  • Posted on Nov 25, 2022
Michael Gray
Contributor
Level 1:
Welcome Back:
Answers
Questions
Helped
868
Points
7
I need master password for Dell Latitude 5420 Rugged.
System: 5YXKDD3-0001
Service tag: 5YXKDD3
express: 12996139431
Thank you!
amir
Level 1:
New Friend:
  • Posted on May 17, 2014
amir
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
868
Points
7ZCT5S1-1D3B pls send me master password
5 Related Answers
leecom72
Lee Hodgson
  • 4810 Answers
  • Posted on Nov 24, 2008
SOURCE: Looking the Bios Chip on a Dell Insprion 5000 Motherboard.
find the bios battery and remove it for al least an hour, make sure the laptop battery is removed and AC power is unplugged
reagards
Anonymous
  • 125 Answers
  • Posted on Oct 31, 2009
SOURCE: where is thebios chip located on the motherdoard
the bios chip on almost all laptops are intergrated you can not replace them it is usally located between the processor and micro processor most repair shops can not replace them they soldered to the board if you done a bad flash go to www.badflash.com they may be able to help you
Anonymous
  • 393 Answers
  • Posted on Dec 07, 2010
SOURCE: Hello i have been working
hello ....
i can help your without removing or changing eeprom chip . just send me service tag i will send u master password..
Anonymous
  • Posted on Jan 21, 2011
SOURCE: Hello i have been working on this dell latitude
MickeyMe43 I have the same problem, whit the same PC, i just want to know if you can solve your ptoblem and helpme solve mine...
thanks
email [email protected]
Anonymous
  • 11 Answers
  • Posted on Jan 04, 2012
SOURCE: dell insprion 1545 master password
IN870BYY
Where can i down load schematics for this the motherboard was made by HamStarr on the motherboard is says Dell DAOVO2MB6EO OR DA0V02MB6E0 ?
Its better to just look up the chip nomenclature of all the chips on the board, One is going to be an NVRAM or EEPROM chip of 2MB or less, usually a very small chip at that. And it may have a sticker on it saying AMI or Phoenix or other BIOS manufacturers.
How do I locate the BIOS chip on the Dell Latitude D610 laptop computer?
most bios chips are solder to the motherboard
If you are looking for the information about the bios, use belarc
Belarc Advisor
Location of bios chip on dell Inspiron 1764
The BIOS chip is soldered onto the motherboard. It is about a 1/2" square chip. The below link is the Dell Inspiron 1764 Service Manual from Dell for the Inspiron 1764. It is in PDF format (Adobe Reader online file, and downloadable).
http://downloads.dell.com/Manuals/all-products/esuprt_laptop/esuprt_inspiron_laptop/inspiron-1764_service%20manual_en-us.pdf
Opens in Adobe Reader so make sure you have the program already installed, or download and install Adobe Reader from www.adobe.com first.
Once the Service manual is opened. Go to the: System board section. Then scroll down to Replacing the Coin-Cell Battery Click on the link...That is the BIOS chip battery. The actual BIOS chip is not a removable chip on that particular motherboard, but a soldered in place chip located on the opposite side (surface of the motherboard) right near that coin-cell battery location. That chip may be reflashed w/ the latest BIOS by downloading the latest BIOS.bin file avail. from DELL at the following Drivers link.
http://www.dell.com/support/home/us/en/04/product-support/product/inspiron-1764/research
Choose Drivers and Downloads from the left>Choose the installed OS Version first>Then choose BIOS from the list. The following choices are there; (only 1 version of OS avail. without the actual Service Tag # appears; Win 7 (64 bit OS)).
Windows 7 64 Bit>Latest BIOS file version is A13 (Released 06 Apr 2011) If that matches your OS (Go to Start>Control Panel>System>General Tab and look for Windows 7 and 64 bit as the type of OS installed, you can also download Belarc Advisor from www.belarc.com and install and run it, allow the hardware and software inventory to load (print out the inventory) if possible, on the right near the top the System board info and currently installed BIOS info will show on the inventory along w/ everything else about that current laptop setup), if so, and Win 7 64 bit shows and the BIOS version is anything less than A13 (a smaller # like A6 or A11...then you need to update the BIOS to the A13 flash), is listed, go download from dell the A13 file, and install to flash the BIOS to the A13 latest BIOS version released. Then delete that downloaded file. You only need to flash it once.
Or go to:
www.dell.com Choose Support>Look on the bottom of the laptop for Service Tag: Number or Tag: and enter the # printed there usually a short combo of letters and #'s. Or you can have it scan for the tag # by installing the provided program. Then once you are at the Inspiron 1764 location>Enter your Operating System Version or flavor installed>Choose Drivers. In the Drivers section choose BIOS, and look for the highest BIOS Version Number and latest file date created.
IF THE MOTHERBOARD will not boot to the BIOS setup Screen (Motherboard BIOS is BRICKED or DOORSTOPPED=Corrupted BIOS, usually caused by incorrect flashing w/ the wrong file, or an inturrupted flashing...Though, sometimes just a dead motherboard BIOS coin-battery type battery replacement, and re-flashing with the latest file will cure the issue though).
And should a new preprogrammed BIOS chip be required to UNBRICK THE MOBO, for the Inspiron 1764. One can be purchased on ebay at the following link, but should only be installed by a VERY qualified technician. (Notice it says on their pic....New chip to be soldered on board). That takes skill to properly handle, desolder and resolder the chip properly. DELL and others can also reflash bricked BIOS CHIPS. Chips that were flashed incorrectly turning the motherboard into the dreaded doorstop.
But if the BIOS setup is reachable (the computer will start and boot to at least the BIOS Setup screen...Usually F2 or F10 or Delete keys. Just watch the screen on boot up, choose the BIOS Setup or Setup key combo listed). If so, (you can get to Setup, then the BIOS Chip is not bricked, corrupted, damaged, or doostopped), In that case, just go download the latest BIOS Version .bin file from the above Dell Drivers Link for your OS version, and go into Windows and double click the file w/ the power adapter plugged in and all other programs closed...follow the instructions, and do not interrupt the BIOS Flashing process (very IMPORTANT!) The computer will simply restart after the BIOS flashing is completed...You may have to go back to setup after it restarts and load default settings if it does not load Windows after the flash, then restart again.
http://www.ebay.com/itm/BIOS-CHIP-DELL-INSPIRON-1764-/400663668014?pt=US_Motherboard_Components&hash=item5d496a652e#ht_928wt_1182
Good Luck!
Webcam driver
Drivers for Dell Latitude E5420 is located here:
http://www.dell.com/support/drivers/us/en/04/Product/latitude-e5420
Choose your OS type then choose the approriate category for Webcam
Factory reset
restart the computer HOLD the CTRL OR FN +f2 or ESC depend of your model , mark, and go to BIOS setup select to the restore factory default, and ready.
God bless you
No POST on my Dell Latitude E5420 after setting Optimus
Go to dell's site and flash the bios.
Get onlineand got to www.google.com In the google search box type: "DellSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the BIOS drivers.
2answers
Dell Latitude E5420
Nice computer, what's the problem?
3answers
Bios chip location
try this link, select your platform etc once selected click on manual from left column, select service manual html view, click on motherboard etc,or post what the laptop is under the ask me tab and I'll point you in the direction.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
