We need the top shelf for a admiral designer series refrigerator mod # HMG211380 it is part rack part plastic that covers the deli drawer
Thank you for any help you can give
Nikki Conway
[email protected]
Hi Nikki, I'd like to help, but your model number is incorrect. Open the fridge door and look for a sticker in there. It should be above the top shelf on the right side.
SG
SG
You can't post conmments that contain an email address.
Question edited for clarity, maker.
Question moved from Watches to U-Line Wine Fridge.
They are usually an expanding plug. You push it to the hole and press the central pin. If you can grip it with pliers, you can pull it out. The other way is to use a nail punch and push the pin all the way through, pull out the support and retrieve the pin from the insulated cavity.
go to the service dealer spares for one
if it is no longer available go to appliance repair shops and ask if there is one from a fridge unit going to the dump
if it is a self defrosting unit then check the operating times of the defroster
if the water is leaking out of the door then replace the door seal
check for a blocked outlet tube for the freezer section
Hi did anyone get back to you on this? I have a KIC Fridge and it does the same... take out the top door shelf/rack but then you MUST unscrew the light (cause otherwise your light never goes off and your food doesn't stay cold) cause the top shelf/rack in the door switches off the light... anyway... once the top shelf is out, the door will close better.... not sure how else to fix it though...
For the GE refridgerator, the model GTS22 is an incomplete model number. That is actually the series number. Your actual model should be followed by 5-7 more letters, as in GTS22FBPBRWW. The full model number denotes dates, dimension, color, etc. You can find the full model number in one of two places: A) Upper front left corner of the food compartment B) Left side of the crisper pan on the food liner (with storage drawer open).
Once you find the correct model number, it is important to decide exactly which parts you need. Each door shelf comes in 3 pieces. You have two end caps (left and right) and then the front piece. For the bottom shelf, the end caps are different than the caps for the top and middle shelf. Also, do you need the dairy door and the butter dish? A schematic drawing can be most helpful.
When you know which parts you need, you can go online to www.partstore.com or call toll-free 866-925-PART (7278).
You just "pop out" the blue clips. Then pull the shelf out and relocate it to your desired position. Lastly, replace the blue clip to the top of the hole where you placed your shelf.
Hi Nikki,
SG
