Question about Polycom Computers & Internet
What chipset do polycom phones run? - Polycom Computers & Internet
On Polycom 335 how do I reset voicemail for new employee
"If you need to remove the resource files from a phone at some later date-for example, you are giving the phone to a new user-instructions on how to put the phone into the factory default state can be found in 'Quick Tip 18298: Resetting and Rebooting SoundPoint IP, SoundStation IP, and Polycom VVX 1500 Phones' at http://support.polycom.com/global/documents/support/technical/products/voice/SoundPointIP_Resetting_Log_Files_QT18298.pdf "
http://supportdocs.polycom.com/PolycomService/support/global/documents/support/setup_maintenance/products/voice/spip_ssip_vvx_Admin_Guide_SIP_3_2_2_eng.pdf
Oct 06, 2014 | Polycom SoundPoint IP 320 SIP IP Phone
Polycom soundstation 2 does not have a dial tone
That Polycom runs off of Analog dial tone.
Either a dedicated line or in most cases from an ATA off the phone system.
You should be calling your vendor/tech in that handles the phone system to check programming, cabel, jack and the Polycom itself too.
Dec 11, 2012 | Polycom Soundstation 2 Full Duplex...
Polycom spectralink 6020 voicemail
All depends what phone system the Spectra runs along side with, call your vendor who installed it or your office manager/admin
Nov 17, 2012 | Polycom SpectraLink 6020 Wireless...
I have a problem regarding my Polycom Soundpoint IP331. It doesn't boot anymore. It shows only an error which is error.cfg.
You need to reinstall all the files back onto the phone. You can get the files from the Polycom Website. You can also follow the instruction from my Polycom 501 Fixya blog to see how its done.
Jun 15, 2011 | Polycom SoundPoint IP 501 IP Phone
How much internet speed is required to run polycom soundpoint 330
For one line, you need both upstream and downstream of 90kbps for good quality.
Mar 02, 2011 | Polycom SoundPoint 330 IP Phone
Polycom IP 330 SIP C Will not boot up
This means the phone's SIP application has been erased. You will need to download the SIP app and BootROM from the Polycom support page, host the files on a boot server, and then point the phone to this server from the server menu so the phone will reboot and download the files.
http://www.polycom.com/support/voice/soundpoint_ip/soundpoint_ip330_320.html
Dec 16, 2008 | Polycom SoundPoint 330 IP Phone
Polycom IP501 and SPA2102 Router
If you know how eo access your configuration control panel then assign a Static IP address or place that assigned address on the other side of the firewall (DMZ). Steve Medley
Nov 01, 2008 | Polycom Computers & Internet
I am unable to push the configuration files into polycom soundpoint ip 330 through tftpd
Aug 28, 2008 | Polycom SoundPoint 330 IP Phone
Computers & Internet Logo
35 people viewed this question
Top Polycom Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Darren  Means
Darren Means
Tom Chichester
Are you a Polycom Computer and Internet Expert? Answer questions, earn points and help others
