Re: Need a grill cover for the redstone 4 way grill
You can see the grill cover here https://bestgrill.reviews/built-in-grills/ by the way, learn a lot about other types of grill and maybe you can look for something new.
The flame is too high. It should be a short blue flame, with no yellow at all. The way to increase the heat of a kerosene heater is to buy a second one! Your wick needs trimming and resetting.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4): Maytag MMV1164WB Owners Manual Page 4
Is this a countertop microwave or an over-the-rang (OTR) microwave? If it's a countertop model, you need to completely remove the outer case to get to the lightbulb. If it's and OTR microwave, there usually is an access cover located behind the grill vent. You can remove that grille vent by removing the 2 to 4 screws above the grill vent. Then either slide the grill vent 1/4" to the left to remove it, or else (depending on the model), just pull out the top of the grill vent, followed by the bottom. Then you should be able to see the lightbulb access cover. Usually there is 1 screw that you have to remove. But unplug the microwave before you to any further! Now remove the screw, lift up and remove the cover, and you should be able to get to the light bulb.
You should be able to get a grill cover from the website MightyCovers.com. They have covers in every shape and size and can make a custom one if they don't have the one that you need. I do not have the owners manual. Sorry I can't help more.
Put a piece of cardboard next to the speaker to protect your boats finish. Then use a flat bladed screw driver to gently pry the grill covers off. you may need to work your way around the perimeter, with a little bit of effort it will pop off. There will be 4 screws under the grills holding the speaker to the boat which are easy to remove.
if you are looking for a replacement cover you can go to any of your loc. bbq galore store to pick one up. All you have to tell them if it a 3 or 4 burner bi or on a cart and they will help you.
