Purchased new version of printshop deluxe 3.5 for windows when older version wouldn't work on windows 8.1 new discs start install but hangs up and still trying to complete after a=2 or 3 hrs
SOURCE: printshop 20 deluxe will not
Yes, it will NOT work on Vista or Windows 7. I had to upgrade to PS 23 on my computer. If you have 7 Professional or Ultimate, it is backwards compatible to accomodate older software. If you have Home Premium, it will NOT work on 7.
Good Luck.
SOURCE: I installed printshop 2.0 deluxe on my new
If a program cannot be run under Windows 7 because of compatibility issues you have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and check the Windows version you know the program worked with before. You can find more about this Compatibility issue on Microsoft website: http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
SOURCE: I purchased printshop 20 deluxe
The Print Shop version 20 Deluxe for PC is not compatible with Windows 7. The newer Version 23 is compatible. This is due to software compatibility issues with Windows 7.
You can check for Win 7 Compatibility for "software or hardware" @ Windows 7 Compatibility Center
It will not run on Win 7, even when you are using the Compatibility Mode options. Too bad you have to get the newer version 23.
Hope it helps.
SOURCE: A couple of problems: 1.
It seems that Broderbund Print Shop 20 Deluxe for PC is for Windows 98 / 2000 / Me / XP.
What you can try:
1. De-install Print Shop
2. Re-install Print Shop in the Windows XP Compatibility mode.
