Question about Kirby G6 Bagged Upright Vacuum
Dont know how to put the shampoo system together on my kirby g6..
We just got a kirby g6 2000 limited edition vacuum i really need instructions on how to put the shampoo system for it together. please help!
Posted by doctorzetta on
Uplate
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 112 Answers
Http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Copy and paste the above link to the address window of your browser for the Kirby Shampooer instructions.
Hope this helps :)
And thank you for using Fixya!!!
Posted on May 23, 2009
I lost my directions for putting the shamoo attachments together can you help?
The Kirby site has a good instruction video for this. Check the " Attaching the Carpet Shampoo System" on the below link.
http://www.kirby.com/Portals/0/videos.html
Dec 07, 2010 | Kirby Vacuums
How to assembel the kirby accesories to manually shampoo
I just did and it's multiple steps but not too hard.
There are complete detailed explanations if you do a search engine on kirby shampooer instructions. I found one explanation on Ebay, and another on EHow. www.goodvac.com/Articles.asp?ID=153
Step one - vacuum your carpet more thoroughly than you usually do. Each back and forth pass - four times.
Take off the dirt bag and the head off of your Kirby.
Where the dirt bag attaches to the Kirby is where the shampoo mixing container goes. Before you attach the mixing container on there take your container and fill it to the 1st line for a very small area, 2nd for a medium sized area, and to the third line for an average sized bedroom. A large living room may need a second container. For the solution - you must use Kirby shampoo. If you fill to the first water line - use one capful, 2nd line 2 capfuls, and etc. Make sure the sponge filter is positioned on the mixing container in the spot where it hooks onto the vacuum (mini-emptor).
The shampoo brushhead I find to be the biggest challenge because that L-shaped tube attachment gets in the way of the belt lifter when you try to hook on the belt. The belt is going to hook on the brushroller the same way it does on your vacuum head. Pop the brush roller in the head of the shampooer and then sit that head onto the tray mechanism.
Once you puzzle piece everything together and now ready to shampoo. Let me tell ya this - after the hassle of putting everything together - just do the whole room and make it worth the bother.
Turn the machine on, and lower the shampoo head ALL THE WAY DOWN, unless your carpet is ultra thick and then maybe just one click up. Turn the dial on the shampoo mixing container to on. Push the machine forward rather quick and pull back slow. Do overlapping passes.This will spread the foam nice and evenly. Let the foam sit for about 5 minutes, then turn the dial to off and go back over it slowly forward and backwards massaging the foam solution deep into your carpet fibers. Then let it sit for 2 - 3 hours. Then vacuum really thoroughly. Right after I go through the shampooing process and the carpet is still moist - I use a carpet brush and I scrub the foam even deeper into the carpet.
Good luck. Hopefully you will be motivated in the fact that I just did mine and the high traffic carpet looks really good. I just had clients come in and they noticed the difference right away, as it looks like a pro came in and did the job.
Mar 21, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Can NOT get Kirby G6 shampooer system lowered to use
take the attachments off and see if you can lower it then..if so .lower the vacuum and put the attachmens on then try
Apr 11, 2009 | Kirby G6 Bagged Upright Vacuum
Carpet shampoo system
MY FIRST QUESTION IS WHAT BRAND OF SHAMPOO ARE YOU USING??? KIRBY IS NOTED FOR REQUIRING ONLY, KIRBY SHAMPOO. PART OF THE REASON IS THAT THEY HAVE A UNIQUE FORMULA THAT WORKS SPECIFICALLY WITH THE KIRBY.
THE OTHER POSSIBILITY IS THE DISPENSER IS PLUGGED AND NEEDS A REAL GOOD CLEANING. ALSO, WHEN APPLYING THE FOAM TO THE CARPET, YOU NEED TO GO REALLY, REALLY SLOW.
THE NARROW BAND OF SUDS DOES INDICATE YOU MAY BE MOVING THE DISPENSER TOO FAST. GOOD LUCK.
Jul 01, 2008 | Kirby G5 Bagged Upright Vacuum
How do i put together my kirby carpet shampoo system?
Vacuum thoroughly before shampooing for maximum cleaning. Then, remove the bag and the Power Nozzle to prepare for shampooing. Turn the Carpet Shampoo System Nozzle Belt Lifter to the right of the center position (fully clockwise) until the green arrows line up. a4bbc62.jpg Slide the slots on the side of the Carpet shampoo system over the outer shoulders of the Carpet Shampoo System Tray. e14fe2e.jpg While pushing up on the Belt with your finger, turn the Belt Lifter left (counter- clockwise looking at it from the front) until the red arrows line up. (The Belt Lifter Hook will catch and stretch the belt.)
Press the bottom Toe Touch Pedal all the way down to raise the front of the Kirby.
While sliding the carpet shampoo system Nozzle/Tray Assembly toward the Kirby and over the Motor shaft, connect the hooks on the bottom rear of the nozzle to the Attaching Bar.
Push the nozzle up against the Kirby and turn the Accessory Lock to the
right (clockwise) to lock the nozzle in place. To engage the belt, turn the Belt Lifter
all the way to the right (clockwise) until the green arrows line up. Then lower the Headlight Hood
Apr 18, 2008 | Vacuums
Kirby shampooer
here are instructions with pictures of how to put the kirby shampooer together...
http://www.greatvacs.com/shampoo.shtml
hope this helps!!!
Mar 28, 2008 | Kirby G5 Bagged Upright Vacuum
Heritage II Model 2HE instructions for a Kirby Vacuum cleaner?
Hi, everybody:
I see no one's given you a solution yet.
Well, I've searching online for Shampooer instructions and I found some at http://www.greatvacs.com/shampoo.shtml
As for the manual, I looked at kirby.com and found a #:
1-800-437-7170.
Hope those help.
Love in Christ, Passionatehearts
Feb 27, 2008 | Vacuums
Kirby G6 Bagged Upright Vacuum Logo
1,539 people viewed this question
Top Kirby Vacuums Experts
Paul Bade
Marvin
Marvin
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
