Washing Machines Logo
A
Anonymous Posted on Nov 08, 2013
F4 on display - De Dietrich Washing Machines
When the indoor unit is on F4 fault error code display.please help to solve the problem.
f4 mean Air Conditioners Questions & Answers - Fixya
www.fixya.com > Forum > Tags > f4 mean
My gree split type ac error F4 what is problem Name of malfunction = Outdoor tube sensor open or short circuit Display of double eight code = F4 this means
Where can i find the minute and second key
In Run screen, press OPTN>F6>F5 (Angl). The Degree/Minute/Second key is the TAB above the F4 Key.
To use the key for example to type in 58 deg 33 minutes, 27 seconds type in 58, press F4, type in 33, press F4, type in 27 then F4. Press EXE. The screen displays 58.5575.
A new tab appears above F5. Press it to convert displayed result to DMS
1helpful
Hp laptop no longer connects to external display via fn + f4
The Fn+F4 button toggles between the LCD and external monitor.
From LCD only or both LCD and external monitor or external monitor.
only. Press the Fn+F4 keys again to toggle the various screen selections.
2answers
F4 message appears on living well pressure cooker what does this mean and how do I reset it pressure cooker not working \
IF you press and hold the top two buttons for 10 seconds the display will show a few numbers.. then press the bottom right button.. ours went right back to F4 and the only thing we could find mentioned is that a "sensor" was bad.. right out of the box this PC was JUNK.. awesome!
I have my G60 laptop connect to an LCD projector. I wanted to turn off the screen on the laptop and hit Function F4 which i have done in the past and it took the picture off of the LCD projector and now...
Disconnect the cable that is connecting the laptop to the projector. Sometimes this will happen if the projector or device you're connecting your laptop to does not support the current resolution that the laptop is displaying. Reconnect the cable and try using Function F4. If that does not work then disconnect the cable from laptop to projector, reboot the laptop then repeat connecting it to the projector and pressing Function F4.
2helpful
Can't find angle measurements function on casio fx 9750
In [RUN], screen press [OPTN][F6:->][F5:ANGL] [EXE].
Exemple 18.53 deg
18.58 [F1 Degree symbol] [EXE] shows 18.58. At the bottom of the screen appears a new option DMS with a left arrow. By pressing the corresponding key [F5], the screen displays 18 deg 34 min and 48 secs. To enter an angle in DMS, exemple the one above, you procedd as follows:
18[F4]34[F4] 48 [F4] [EXE] displays 18.58
Hope it helps.
F4:2398
enter in setings->restore factory setings->tipe the password and then click ok->the phone will be reseted on setings.Thanks
8helpful
Which function key allows to switch to tv
You need to press hold the FN key and press the F4 function key once which toggles the display to the External Display source like the television connected along with the LCD of the Notebook.
If the FN and F4 key combination is pressed again, the display will dissappear from the LCD of the Notebook and remain only on the external source.
If the FN and F4 key combination is pressed third time, the display will be back on the LCD of the Notebook and will not remain on the External display source.
Here are these details in other way :
First time pressing FN + F4    ---> Display on LCD and External display
Second time pressing FN + F4 ---> Display not on LCD but on the External Display
Third time pressing FN + F4 ---> Display back on the LCD and not available on External Display (Normal position).
Below are the details of what the Function keys in your DV1000 Notebook work :
fn + f1 Opens Help and Support Center fn + f2 Opens print options window fn + f3 Opens default Internet browser fn + f4 Switches the image among displays fn + f5 Initiates Standby fn + f6 Initiates QuickLock fn + f7 Decreases screen brightness fn + f8 Increases screen brightness fn + f9 Plays, pauses, or resumes an audio CD or DVD fn + f10 Stops an audio CD or DVD fn + f11 Plays the previous track or chapter on an audio CD or DVD fn + f12 Plays the next track or chapter on an audio CD or DVD fn + esc Displays system information.* (*To clear the system information display, press esc.)
Hope this helps...
2answers
F4 Error
in the middle of sewing the machine made a loud noise and then would not run just chaters when you push the start button its like it is jambed the model is cs80
Top De Dietrich Washing Machines Experts
john h
Are you a De Dietrich Washing Machine Expert? Answer questions, earn points and help others
