KitchenAid Architect ® II KEBS208S Electric Double Oven Logo
Question about KitchenAid Architect ® II KEBS208S Electric Double Oven
Ovens won't heat up beyond 250 degrees.
My Kitchenaid KEBS208SSS is only 14 months old and just this week stop working correctly. Both ovens will not heat up beyond the mid 200 degrees and it takes about an hour just to get to this temperature. As far as I can remember this oven seem to take a long time (15 - 20 minutes)to preheat to a set temperature such as 375 - 400 degrees. My email address is [email protected] Thank you for any suggestions you may have for me.
Posted by edyee412 on
  • edyee412 May 02, 2009
    Thanks for the input but I checked the control panel and the option setting is still on Fahrenheit.
Anonymous
  • 125 Answers
If you cant program it for more than the 270 you may have changed it from farienhiet ( bad spelling) to celcius. pushing and holding broil may switch it back.
Posted on May 02, 2009
I own a Kitchenaid KEBS208SSS double convection oven. The upper oven does not heat up. The bottom oven works perfectly. Thanks, Chaz
You need to pull the oven out and see if you are getting 240 volts to the bake element (take the back panel off, press bake and start and put your meter lids on each prone of the bake element).
If you do get 240 volts to the bake element then the element is defective. If you don't get 240 volts then you may be looking at a faulty relay board.
Appliance Repair Brooklyn
http://appliancerepairbrooklynnyc.com/
I recently ran the self-clean option on my GE Profile JK955B0F5BB. Now when I set the touch pad to 350 degrees or more, the oven heats up to beyond 500.
That is not a valid model number, the issue is most likely the thermostat has failed. The part is about 12 dollars.
Jan 07, 2017 • GE Ovens
Smoking near top heating element upon initial operation
Some oil of some kind must've been on the heating element. No worries.
Ykemc308kmo oven fan noise
You are probably correct the cooling fan can wear out. You will have to order it by model number. They are a bit tricky to install depending on the oven, but not hard once you get to the fan area. Somke are behing the cabinet and you will have to puul the oven out and some are in the control panel area.
2helpful
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Model KEMS308sss microwave not heating - light comes on, turntable works but no heating. Unit is 4 months old.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
5helpful
2answers
Kitchenaid superba electric oven kebc107kss05
Did this with me twice now on self clean. It's the thermostat on the back of the oven. Set to trip when oven gets too hot which happens with self clean. Part is about $45 - $50 and pretty simple to install. Hardest part is pulling the oven out of the wall.
Nov 11, 2008 • Ovens
2answers
Older Whirlpool RB170PBX both ovens out
these ovens have a fuse in them called a tco thermal cut out switch if the ovens over heat for a varity of reasons it cuts the power and must be replaced most are on the back of the ovens and are metel disc with two wires on them
2answers
DOUBLE OVENS FROM KITCHENAID
Redhead Do nothing and call the manufacturer. Your oven has one year warranty. Gendos...post back
Top KitchenAid Ovens Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
