Panasonic SA-HE70 Receiver Logo
Question about Panasonic SA-HE70 Receiver
Dish network Remote Control Codes for Panasonic sa-he70
5 Related Answers
Anonymous
SOURCE: Panasonic SA-HE70 Sub Out Problem and Standby
hi i would try a new lead, try a normal audio phono lead , or at worst a dry joint at the plug on the amp, there are only 2 joints , so easy fix hope this helps. Ray
Posted on Apr 09, 2007
Anonymous
  • 298 Answers
SOURCE: Panasonic SA-HE100 Remote
The correct replacement remote from Panasonic can be found in the link below.
Panasonic SA-HE100 Replacement Remote
Posted on Jun 25, 2008
Anonymous
  • 6 Answers
SOURCE: Need 5 Digit Remote Code for a Panasonic Receiver HE-100
Try 1518 or 1039
/www.comcast.com/remotes/universal.html
Posted on Dec 12, 2008
smarthome2
Frank Fulton
  • 1114 Answers
SOURCE: To smarthome2 Regarding the panasonic SA-HE70
Not very likely. Even to find one is a tough job. If you do find a source, expect to pay between 20-30 for it. I will look as well for you. If I find it, I will post the link or get a pdf if lucky!
Posted on Dec 23, 2009
Anonymous
  • 8546 Answers
SOURCE: I have a panasonic sa-he70
Page 16 of the manual has recommendations.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Jul 27, 2011
CD function not working on Panasonic SA-HE70 receiver
when you say its not working what do you mean by that?
its got no power.
the tray wont open.
tray trying to open but wont.
or just wont play cd.
if none of the above could you please give me more info please.
I have a button that allows bass/treble and balance but only balance works regardless of how many times you press it.
Read Page 13 of your owner's manual http://www.manualslib.com/manual/119549/Panasonic-Sa-He70.html?page=13#manual
Am looking for a manual for an SA-HE70 av control manual
Crutchfield has the manual for the Panasonic SA-HE70 on their product sale page: http://www.crutchfield.com/S-6TiEMal3qmL/p_133SAHE70K/Panasonic-SA-HE70-Black.html . Look at the Details tab. The direct link to the manual is http://www.crutchfield.com.edgesuite.net/pix.crutchfield.com/Manuals/133/133SAHE70K.PDF .
I hope this helps.
(You will need Adobe Reader or a similar program to read or print the manual.)
Universal code for panasonic dvd
0028,0022,0027. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Codes for Panasonic SA-HT720 using dish network remote (21.1)
Hi, Cheri Torres with DISH Network Customer Service here. I came across your post and wanted to see if I could help. The best codes for a Panasonic sound system for the 21.1 IR/UHF remote are 2643, 2672, 2677, 2678, 2715, 2749 and 2843. I will also list here for you the instructions for addressing the remote to the Panasonic sound system using these codes. I hope you find this information useful and if you have any further questions please let me know.
Instructions for addressing the remote to the sound system
  1. Press and hold the AUX mode button until all mode button back lights come on, then release.
  2. Use the number buttons to enter the device code corresponding to the equipment.
  3. Press the POUND (#) button.
    If the code entered is valid for the remote, the mode light flashes three times.
How to hook up external amp need to know how to run jacks to the amp and speakers which out put for amp to run the front speakers on a panasonic sa-he70
Manuals help.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Panasonic-SA-HE70K-Receivers-manual/id/312ag701/t/2/
Not knowing anything about your 'external' amp or how you want it to function the only thing you could do is feed it the analog stereo output of the SA-HE70 from one of its OUTs (Tape or VCR). It won't be volumed-controlled by the SA-HE70.
I need the dish control code for panasonic tv
Hi jennyhilariomy name is Mike Houston of DISH Network and I was going over your post and Iwanted to give you the codes for your Panasonic TV. The codes are: 700, 734,864, 512, 673, 685, 566, 644, 234, 247, 676, 765, 625, 668, 662, 663, 689, 508,698, 716, 701, 239, 510, 761, 672, 509, 651, 747, 638, 439, 852 and 500. I willsend the link that will help with the setup http://www.dishnetwork.com/SupportSection/remote-setup.
3answers
I need a remote code for a Dish Network VIP722k DVR that will be used by my Panasonic TV remote to control the Dish Netwrk DVR using my Panasonic remote. None of the Dish Network codes listed in my TV...
Try these codes:
3-digit codes:
512, 689, 508, 509, 510, 566, 644, 651, 662, 663, 668, 672, 673, 676, 685, 698, 700, 716, 734, 747, 761, 765, 003/ 054/ 055/ 062/ 070/ 148/ 149/ 170/ 171
4-digit codes:
0051, 0055, 0250
One of these codes should work.
1helpful
Can't play iPod on my panasonic sa-en27 with out a remote
I ran into the same issue, instead of buying a replacement remote I was able to dial in a Vip 211 dish network remote control with remote code 643 in AUX setting. Then once the code was in, i pressed the 6 key on the remote and now I can listen to audio on the music port. The 643 code refers to the first Panasonic amplifier/receiver in the code list. To further clarify, I pressed AUX for 4 seconds, pressed 2 to signal I am programming an amplifier/receiver device, then punched in 643 then pound sign.
Good luck with yours.
Panasonic subwoofer
Any active subwooofer. I have an HE70 as well and I am using the SONY active subwoofer.
Top Panasonic Audio Players & Recorders Experts
Marvin
Marvin
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
