Brother PE770 Computerized Sewing Machine Logo
Question about Brother PE770 Computerized Sewing Machine
Lower Presser Foot message when presser foot is down
My PE770 embroidery machine keeps saying lower presser foot when the presser foot is already lowered. It is not recognizing when it is in the down position. I tried restarting the machine but that did not fix it. What could be wrong and how can I fix it?
Posted by Audrey on
andel jackson
  • 34 Answers
You may need to check the switch in the foot presser
Posted on Nov 09, 2013
Raymond Paradise
Removed foot pedal restarted machine fixed problem.
Posted on Dec 03, 2021
Rebecca McCoy
    New Friend:
That was my issue i lowered it it was fine but now it's closing but giving me error message again.
Posted on May 16, 2017
3 Related Answers
ohms
monk3ybidzness
  • 1879 Answers
SOURCE: presser foot lever
Try turning it off and disconnect the foot pedal (depends on the model).
Worst, the power surge damaged the sewing machines small computer and it will require service.
Posted on Nov 24, 2008
Anonymous
SOURCE: "Lower presser foot" error on SE 270D
This happened to me and I eventually realized that there is a small door flap at the top near the "4" in the threading series that can get stuck open. Normally this flap goes up and down with the presser foot, but if it gets stuck open even when the presser foot is down, tapping it or closing it manually will make the error go away.1_9_2012_12_19_55_am.jpg
Posted on Jan 09, 2012
SOURCE: The face says lower presser foot, but I can't sew.
it's possible that something is wrong with the computer part of the machine
& needs to be checked
Posted on May 21, 2012
Error message foot too high. To correct this, it is necessary to restart the machine. Unless it is impossible to continue sewing.What is the problem?
Try taking your presser foot off and lower the presser foot lever. Does the error code go away? The machine won't sew without the presser foot to hold the fabric down, but without threading the needle, will the machine run without the presser foot? Now try the standard presser foot (usually J ) and if you get the error code then the sensor at the top of the presser foot assembly is out of adjustment. Without knowing more about your machine this is all I can suggest.
Good luck,
Bob
Can I do freehand embroidery using this machine?
Most any sewing machine (zig-zag capable is probably better but a straight stitch can be used) should be able to do manual embroidery/applique. The lady in the video states she's using an embroidery foot, but in reality a darning or free motion presser foot may be better. Most embroidery presser feet actually press down on the fabric making it difficult to move the fabric manually. A darning or free motion presser foot is actually shorter and allows space for the fabric to move freely.
Don't forget to lower the feed dogs!!!
Lots of web sites and videos on the internet!
How To Do Free Hand Machine Embroidery
https://www.youtube.com/watch?v=6vAmmmNbL88
When trying to embroider I keep getting a Lower the Presser foot message when it is already lowered!!
You don't state the brand/model of your machine. If it is computerized model, the machine is not recognizing the presser foot's position. If there is a glass eye on the foot, make sure it is clean of any dust, lint, or fingerprints.
How to bring sewing foot holder to embroidery position
Hi, I hope this helps. If it doesn't post again.
"Check:
Place the sewing foot under the sewing foot
holder so that the pins of the foot snap into
the sewing foot holder when the presser foot
lifter is lowered.
Please check that the sewing foot is properly
engaged by raising the presser foot lifter
Question: Are you using top feed? If so:
"For all sewing jobs with the top feed, only use sewing feet with Cutout at the back (OA, 1A, 3, 4)."
Embroidery foot Part No.: 98-694-840-00 will not work with top feed.
Also, except for eyelets, the darning foot can be used for embroidery.
I'm not sure what you're trying to do :) darn or embroider :); I'm not sure what mode you're working in either; embroidery mode?
Darning with straight stitch
Program 00
Fit darning foot No. 6.
Set the needle at its highest position by turning
the handwheel, and push the pin of the darning
foot fully into the hole of the sewing foot holder
slightly pressing the darning foot between thumb
and forefinger. When doing this, the guide fork
should place itself around the presser bar and the
wire must be behind the fixing screw.
Darning position:
Lower the presser foot lifter pressing it lightly to
the rear until it snaps into the darning position.
Important Only in this position you have the
optimum thread tension for darning.
• Place the darning work in the darning hoop.
• Lower the feed dog.
• Pull up the bobbin thread and hold the threads
when you start sewing.
• Now guide the fabric back and forth evenly;
the length of the darn will be set by the size of
the hole. As you are determining the stitch
length yourself while sewing with the feed dog
lowered, you should sew at an even speed.
When you have reached the width of the dam
aged area, darn over the damaged area again
from right to left.
This guarantees a durable darn.
TIP: The faster you sew, the easier and more even
the darning will be. It you are moving the workpiece
too slowly, small knots will appear on the
wrong side of the fabric."
Whether working with terry-cloth or woven fabric,
with the help of the darning foot and the pro
gram 02 you can embroider initials of your own
design
Drop the feed dog and insert the darning foot.
Put the machine into the darning position.
Spread the fabric in an embroidery hoop and
embroider in accordance with program 02.
Lower feed dog
If the feed dog is not lowered for embroidering, the
machine does not embroider when the foot pedal
is pressed and the message appea rs:
Lower feed dog
ok?
The feed dog must be lowered in embroidery
mode.
3answers
My Singer XL 6000 upper thread is too tight and keeps breaking, when the presser foot is up the upper thread is loose, but when the presser foot is lowered the threah gets too tight, what I notice is that...
You need to loosen the tension on the machine. There is a dial that has numbers on it. The higher the dial is set, the tighter the tension is. Turn the dial to the left one number. Then try it. Do it over and over. Do not turn the dial all the way down or you will mess up your machine. Do it slowly, one number at a time and try the machine between dials.
1helpful
Cant get machine to embroider
there are three positions the presser foot can sit in. Up and down are the same on any machine. The 7570 has an in-between position for embroidery. Lift the presser foot and the lower it slowly while pushing gently. It should stop about half way down. The embroidery foot pushes the foot into the down position with each stitch allowing the fabric to move easily to the next stitch.
2answers
How to stich embroidery
That would depend on if you have a regular home sewing machine or a embroidery machine. I'm going to assume that you have a regular machine.
There is something called free hand embroidery. you lower or disengage the feed dogs, take off the presser foot. Some use a darning foot and others just leave the foot off. Hopefully your design is already marked on the fabric. Place fabric in a regular hand embroidery so they fabric is right side up but the hoop makes it sit down in the rings. (make sense) Fit your hoop on the bed of the sewing machine, under the presser foot/presser foot bar. Lower the presser foot lever. (important for tension) and select stitch style and length. you may need to adjust tensions too.
Begin stitching, take a couple stitches... then reverse a couple... then snip the loose ends. Continue to stitch, guiding the hoop so that the needle follows the design. Start slowly and as you discover how your hand movements effect the length of the stitches... you can speed up and slow down as you need to create your design.
https://www.youtube.com/watch?v=ylMy6QdsZr4
HOW DO I ATTACH PRESSER FOOT G TO MY MACHINE??
there are 2 type of presser bar foot clamps
one allows you to snap on the foot--raise & then lower the presser foot holder until the cut out is directly above the pin on the foot,,as you lower the presser foot holder the presser foot will automatically engage when put down on the pin area
the second is a shank & foot combined & there is a screw on the presser bar,,unscrew it some & put the shank up around the screw & retighten the screw
Presser foot lever won't lower the foot
This may be a lubrication problem on the presser foot shaft. Try freeing up with penetrating oil or Triflow. After letting set for an hour lower the presser foot and pull down on the ankle. If that does not work you need to open the machine and loosen the clamp screw on the presser foot shaft. Then try to twist the shaft to loosen it up.
Presser foot wont raise and lower
Does the presser foot move at all when the machine is first turned on?
Do the needle and feed teeth calibrate when the machine is first turned on?
You probably need to locate your nearest authorized repair center.
Top Brother Sewing Machines Experts
David Shaub
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
