Sony DVP-NS575P DVD Player Logo
Posted on May 01, 2009
Black rectangle appears on screen while trying to watch movie
Black rectangle appears on tv screen. TV is fine
Anonymous
Level 1:
  • Contributor 30 Answers
  • Posted on May 02, 2009
Anonymous
Contributor
Level 1:
Answers
30
Questions
0
Helped
11171
Points
71
This happens all the time, on your remote, go into the Menu and disable Closed Captions. It will go away after that.
1helpful
Why are the movies half screen?
Movies that are created for "Wide Screen" viewing show up in letterbox on your TV. If you go to a theatre you notice it is a big rectangle. To be able to fit all of the widescreen movie on a TV it has to make the height smaller.
Because many people want to see the "complete" Movie, the "Letterbox Format" came about. I do NOT know what the word "Letterbox" actually means, or how that term was chosen. To get the complete Rectangle into that Square, they discovered that they could shrink the entire rectangle to fit that square. Meaning, what used to take 2 inches on your screen, now may only take 1.75 inches. Now a problem arrose. When you shrink the WIDTH to fit your dinky Square of a TV, the HEIGHT also has to be shrunk along with it, or else you're stretching the image as if it was on silly-putty ("Compression"). When the image was shrunk to fit the TV Screen, they were left with a gap at the top and bottom of the screen. So they simply fill it in with "Black". I guess the only alternative was to leave it snowy.
A black rectangle appears in my screen and it doesn't go away
The closed caption function is ON with your TV now. Make it OFF.
We have a black rectangle appearing on TV when playing DVDs and can't get rid of it. We were setting up to watch a DVD, pushed some buttons inadvertently on the remote and ended up with menus that we...
it sounds like someone turned on the text box on the closed caption feature on the set there may be a button on the remote or look in the set-up features in the main menu
Techman.
2helpful
Black Rectangle appears on screen for no reason
Just use your remote or the tv menu to turn off closed captioning.
Black rectangle on screen
The box you're seeing is the "closed caption' box. You need to use the remote and disable CC mode on it, and the box will go away :)
Using rooftop antenna through converter bos to RCA TV
Turn off the text box function of the closed caption decoder on the tv.
Trouble viewing DVDs
I signed up for the "chat" and the problem was solved very quickly. Thank you - great service!
Black Rectangles on 42" Vizio HDTV LCD
Your DirecTV signal is probably too low. That would produce the small black rectangles (pixilation). Also, try replacing the cable you are using to get the signal from the DirecTV receiver.
Unwanted black rectangle on the TV screen
I'm not sure what type of TV you are using,, but most all Large Screens have a reset button someplace. You should be able to reset the TV and fix the problem. Its not the remote, making the image appear, but a command from it was misinterpeted. Sometimes turning the set off will work, but most often it needs to be reset.
EXCEPTION... if you are using a cable box. Disconnect it from power, wait 1 minute and then see if the problem exists. If the cable box is on even with the DVD you may still have this issue. Please reset the cable, and if that doesn't work, reset the TV.
Thanks! //D
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
