RCA F32669 32" TV Logo
Posted on Oct 04, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Guide Plus My TV has RCA's Guide Plus and I don't use it. Is there a way of preventing it from coming on every time I turn the TV on? Thanks.
A
Anonymous
When the guide is on scroll to the right until you see setup then scroll down to review options. There you should be able to turn the guide off. Hope this helps.
Vista Electronics
Level 3:
Genius:
  • Master 1,694 Answers
  • Posted on Oct 04, 2007
Vista Electronics
Master
Level 3:
Genius:
Answers
1694
Questions
Helped
586334
Points
2786
Not that I could find in the owners manual. Push guide or clear to exit.
4 Related Answers
Anonymous
  • 3130 Answers
  • Posted on Oct 16, 2007
SOURCE: RCA 27" TV Guide Plus
If you have the set off, and the cable plugged into the back of the set for a day or so, the guide plus should come back. It will sometimes take up to 48 hours. If it does not, there is a problem with the set and will require servicing. Good Luck
Lost_Like_U
  • Posted on Feb 11, 2008
SOURCE: RCA TV f27422 TURN OFF THE GUIDE PLUS
Try this;
http://tv.rca.com/en-US/RLDetail.html?ArticleNum=2013
It gives you a step by step instruction on how to turn the Guild off.
Anonymous
  • Posted on Feb 23, 2008
Hello, I have had my TV for 3-4 years and have dealt with this stupid guide popping up for the last 2 when I got curious to see if it was something I wanted to use. FINALLY I came across a solution - so far so good but tomorrow it could be back? I did not have the option field some suggested to use. So saw another suggestion for something else and so far so good. When going into the setup guide. Select the USA, place all 0's in the zip code area and NO for everything else.... no VCR no cable, etc.
Hope this helps..
I also was able to do this without the remote - IF you can get the menu to pop up you just have to use the numbers to select what you need. Found the remote and saw nothing different as far as menu options. Good luck.
Anonymous
  • 17 Answers
  • Posted on Aug 19, 2008
SOURCE: RCA tv with guide plus comes on and off randomly
these tv's are bad for caps in power supply, fluctuations freaking your micro.
My good tv died.rcs guide plus is a loaner. thanks for answering. I thought this tv was newer.thanks for your time
RCS guide? Romanian Cable Service? I think you need to post the brand and model of TV you are inquiring about with a specific question to be more likely to get a response. However, I am guessing you meant to type RCA. Here is a link to a manual:
https://www.manualslib.com/manual/888054/Rca-Guide-Plus.html
RCA Home Theater Premiere 36" TV comes on automatically
Only two possible reasons I can think of for this--
ONE: you have looked in the customer menu and there is no item listed as Timer?
TWO: Does THIS SET HAVE THE GUIDE PLUS LOGO ON THE FRONT OF THE SET? IF IT HAS THE GUIDE PLUS--YOU WILL FIND IT IN THE MENU ALSO---
LET me know if it has the guide plus feature and I can tell you how to end the problem--most of these the set will come on at the same odd time and usually with volume up high.
SD TECH
26helpful
5answers
Help me remove the Guide Plus Grid on my RCA television
Simply enter 00000 for the zip code and complete the set up process; if you're in Canada, select the USA as your country and use the zip. However, you MUST complete the set up, including allowing the TV to search for appropriate code. In the long scheme of things, location and codes don't really matter because you won't see the GUIDE again.
Rca guide plus gold 32'
pull the ac plug for about 5 min and start your set up again paying atention to the features you want and don;t.set the menu to suite your requirements.
2answers
Guide plus rca tv how do stop it from coming up when turning on tv
I have a rca tv guide plus that has the back pannel lights on, but is unplugged, what is the problem?
1helpful
2answers
RCA F32450 TV
Question?
Whenever I turn on the television, the GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes on.
Answer:
The GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes up when you use the TV button on the remote to turn on the TV. There are several ways to turn off this function if you wish, depending on your model.
Option A:
Select the GUIDE Plus+™ Menu from the Main menu.
Select Setup.
Select Options.
Select Off.
Option B:
Select GUIDE Plus+™ Auto Display from the GUIDE Plus+ menu.
Select Off.
Option C:
Press GUIDE on your remote control.
Select the Menu bar.
Press the right arrow button to select Setup.
Choose Review Options.
Select Off.
I know Option C worked for me!!
Given the many TV models, it's possible that accessing control of this feature in the Program Guide menu may differ on your TV. For specific instructions for your model, see your owner's manual.
12helpful
3answers
RCA Guide plus gold gemstar T.V
I have a guide plus gold gemstar tv and I cant program my direct tv remote or Innovage jumbo remote to operate the tv, can anyone help?
Guide plus and main menu problems!
One of you control buttons may be stuck. I found this problem once.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
