Question about Neff B1476 Pyrolytic Stainless Steel Electric Single Oven
Neff B4562 Pyrolytic Cleaning Not Working
I have a fairly new Neff B4562 oven. I recently tried to use the pyrolytic cleaning function for the first time and it doesnt work. I removed the trays, racks and the rails so it is totally empty but when I try to start the cleaning function it just 'beeps' and wont start, indicating that the trays/racks are still in the oven. Any ideas?.
Thks
Posted by tatumm on
  • Anonymous Mar 25, 2014
    function selector not working
Anonymous
You need to remove the rack side supports too. Its not clear in the book as it just says shelves and racks but everything needs to come out the oven.
Posted on Sep 11, 2009
Can anyone tell me if my Neff B1451 is a 13a oven or not.
if its a single not double oven and is not a pyrolytic cleaning system it will work on a 13 amp supply.
Jan 02, 2017 | Neff Ovens
Tip
If the door is locked shut after self cleaning
- Let the over cool down - unplug at the mains and leave it unplugged for a good minute or so - reset the clock The door may well open now. It happened to me today !
on Aug 13, 2007 | Neff B1476 Pyrolytic Stainless Steel...
How can I open a stuck oven door after running the cleaning programme?
Did you release the lock on top of oven door? Oven would not start cleaning until this lock is in place.
Mar 23, 2016 | Ovens
How do I clean the electrolux oven? It won't start after i take the racks out
As you did not specify the exact model I assume that this is a self-cleaning oven, in other words with pyrolytic cleaning. It has a microswitch which is activated by removing the racks and just because that you can not run the pyrolytic cleaning otherwise racks would be destroyed. Do not forget that the temperature during pyrolytic cleaning is app. 500 degrees Celsius. For that reasons the oven door is locked when temperature increasing to app. 300 degrees and unlocked when the temperature decreasing to the app. 200 degrees. It is clear that when you remove the racks only program that you can run is pyrolytic cleaning.
Dado
Oct 10, 2014 | Electrolux ICON Designer E30SO75ESS Oven
Neff B4562
Engineer is a solution.
The other solution is;
Switch 3 times between rotisserie and pyrolysis or bread baking setting and pyrolysis.
As acknowledgement the displays are actuated.
At each change of operating modes switch immediately stops the current test step and the next step of the test enabled. The oven light should according to the mode ON or OFF; that is, at pyrolysis OFF otherwise ON.
Jul 01, 2012 | Ovens
Mile Pyrolytic Oven got a PY flashing
Mine is doing this too. Did you find a solution?
Apr 05, 2012 | Miele Ovens
Pyrolytic cleaning won't start. Neff B15P42.0 GB
you have to remove the shelf supports (left and right) as well as the shelves. The manual tells you about the shelves but not the supports. I only found out as someone wrote the answer on another website
Sep 10, 2009 | Neff B1476 Pyrolytic Stainless Steel...
FAULTY TIMER/CLOCK
I found mine did the same I pusshed the face and it came back on. It appears fault within circuitry of clock and will need to be replaced
Dec 14, 2006 | Smeg F170 Pyrolytic Stainless Steel...
Neff B1476 Pyrolytic Stainless Steel Electric Single Oven Logo
Top Neff Ovens Experts
Paul Carew
xxxxxx xxx
john h
Are you a Neff Oven Expert? Answer questions, earn points and help others
