1988 Troy built pony tiller. I'm looking for the throttle linkage diagram. The tiller look like there isn't throttle linkage up to the carburetor from the bottom of the gas tank. It also looks as though no throttle linkage on the carburetor. Was the throttle control on this tiller just using the governor?
SOURCE: linkage hook up for a briggs and stratton engine
wow, i have not ran into this problem yet. I am not getting any results for that engine in my usual locations, which have great diagrams. here is a link to the only diagram i can get a hold of. hope this works.
http://www.m-and-d.com/pdfs/briggs/135200-ms2810-0802.pdf
SOURCE: changing the drive belt
remove plastic belt cover
remove the guard,belt/pulley
work in the right side first:
remove the rigth-side wheel
remove the screws of the bumper
remove 2 screws on bracket/transmission assembly
pull the bracket
install the new belt
reinstall the right side screws and wheel
do the same in the left side
Ps: remove the belt guide, and reverse return spring
http://www.partstree.com/parts/?lc=troy_bilt&mn=21A-634K766+7HP+FRT+Roto-Tiller+(2005)&dn=0079200009
SOURCE: how to take motor off frame troy built tiller
The easiest way is to first remove the drive belt , then on both sides you will see two bolts with locking nuts on them where the engagement lever raises the motor to tighten the belt. Back these bolts out , then have someone hold the motor while you work the rod out on each side that the motor slides up and down on. Oh if you have a bumper there are two bolts in the top of each one holding the bumper on to take out first. Hope this helps.
SOURCE: I have an older Troy-Bilt Pony Garden Tiller witha
From what I read you need a new rewind clutch and the spring and cord go into the housing. Briggs is easy to fix. contact me at [email protected] and I can send you what you need or you can send it to me and I will repair it very cheap!! Parts are available at almost any small engine parts place.
SOURCE: Changing Drive belt On Troy Built Tiller
You have to remove the engine (4 bolts, no big problem), then remove the bolt in the center of the pulleys, then remove the pulleys. Slip the belt(s) (2 if you have the Super Bronco model) onto the pulleys, re-attach the pulleys with the bolt, re-mount the engine, and you're home free.
